Old 08-06-2013, 10:26 AM   #1
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
Fuse # to the Fog light's
I have HID's on my FR-S Foglights. the Left side is on but not the right side. I'm thinking it's probably a fuse issue or a ballast. I was thinking of checking on the Fuse first before going back to my guy who installed it for me which is covered under warranty. I just don't want to bother the guy with fixing my fog light issue for the third time lol.
914_WHITE_FRS is offline   Reply With Quote
Old 08-06-2013, 10:38 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If the fuse is for both fog lights, which I can only assume it is, then if one of them is working, the fuse is not the problem. Do you get alot of fog in Westchester?
Old 08-06-2013, 10:42 AM   #3
914_WHITE_FRS
sometimes yes, but I like to turn them on just for the show because my fog lights are 4.5K HID's which is not that bright it just makes the car stand out really good. so if one of the fog lights is on and the other side is not, it's perhaps the ballast. Sigh:: I really hate bringing it back to these guys again for the third time.. It make's me feel like i'm annoying them lol
Old 08-06-2013, 03:40 PM   #4
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Does it use one fuse or two? On the BRZ there are two fuses, one for each side. If there is only 1 fuse then it is either the wiring, ballast, or bulb that is bad. It's easy to test with a voltmeter.
Scenic Driver is offline   Reply With Quote
Hot fuse tap - Which fuse? cgrey Electronics | Audio | NAV | Infotainment 9 09-17-2016 07:24 PM
Anyone know if trunk light has a fuse? convoy Cosmetic Modification (Interior/Exterior/Lighting) 2 04-15-2013 05:57 PM
Where to get Fuse Cover? boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 11 01-03-2013 09:02 PM
Where to get Fuse Cover? boredom.is.me Electronics | Audio | NAV | Infotainment 2 01-03-2013 12:32 PM
Fuse Location Shadow215 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 08:07 PM
