Drives: 2019 BMW ///M4
Which wire is "Low Beam"?
Hi All:
I have a 2013 10 Series FRS, I'm trying to install fog lights onto it. I watched the Diode Dynamic Video and in the video there is a red/black wire only. On my car, I have TWO REDs and ONE black. I've googled search the wiring and it says Low Beam is Light Blue? Which I really don't think so. ![]() Could someone tell me which wire to tap into? Whether it's the Red Wire with the Stripe, the Red Wire with Silver dot? If I had a volt meter I would run a test, but I don't have one.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#2 |
Bummpppp.... Help?
N1rve
#3 |
Drives: 10 Series #974 6m/t
Hey wats up hopefully I can help. I too have a 10series and the way I tapped the wires was into the side marker lights. The black wire from the foglights are connected to the black wire in the side markers. The red wire from the foglights are connected to the white wire on the side markers. Best of luck on your install. Foglights would then run under the park lights.
#4 | |
Drives: Asphalt FR-S
Sent from my Nexus 5 using Tapatalk |
#5 | ||
Since black is ground, can't I just tap it to a screw? Quote:
I did talk to them and they said I can also tap into the side markers... I was a little confused from their message so I didn't wanna keep bothering them... LOL
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension Last edited by N1rve; 04-18-2014 at 05:17 PM. |
#6 | |
Canadian FR-S Member
Drives: FR-S '10 Series'
From the picture it looks like you are going from the driver side? The low beam is pin#5. I know it's thicker and red with a brown plug on the passenger side. This is confirmed because I wired my resistor to it. I'm not 100% on driver side, The colors seems to differ on the driver side so I suspect (logically) it is the thick teal one with brown plug. |
#7 | |
N1rve
#8 |
Probably so. I hear a lot of people tapping into the Sidemarkers with the diode kit. Let us know how it goes and installed pics.
#9 |
Yes they will come on with park lights. Keep us posted hope it will be an easier install for you by tapping into the side markers. If it helps I also purchased the Diode Dynamics kit which is awesome for the price.
#10 |
Run, Reach, Fly
Drives: Monogram Firestorm
Op the solid blue wire in your picture is the low beam. The Brown under that is your led.
In the passenger side solid red is low beam, Brown is led. Tap into the blue if you want fogs to come on with your low beams. |
#11 | ||
![]() The solid red? On the connector on the left (with like 5 wires?)
N1rve
#12 |
Run, Reach, Fly
^ yep that's the low beam. I'm guessing this is a shot of your passenger side?
#13 |
Yes it is.
N1rve
#14 |
Run, Reach, Fly
How's the install? Got it to work?
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
