Old 04-15-2014, 09:58 AM   #1
MasterofNim
Drives: 2013 86 GTS C7P AT
Rear seat release straps
Hi from Australia.
I'm hoping one of you fine American chaps or gals can help an Aussie out. I've deleted my driver side key hole and now need a way of unlocking the rear seat from inside the trunk to gain access to the cabin if I have a flat battery etc. The FR-S has pull straps because of the valet feature and they are what I need.
Can someone provide me with a part number please? I have done part searches but this part doesn't come up. I've emailed a dealer in the US but had no response. My local dealer says to get a part number and they'll see if they can order them. I've had no luck ordering TRD parts previously so there is only a slim chance they can order them.
Here's hoping.
Gary.
MasterofNim is offline   Reply With Quote
Old 04-15-2014, 10:08 AM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Its part of an assembly
http://www.villagescionparts.com/sho...rchString=SEAT BACK
You want PN SU00301818
supramkivtt2jz is offline   Reply With Quote
Old 04-15-2014, 10:36 AM   #3
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
...So how do you put your back seats down now?
mkivalex is offline   Reply With Quote
Old 04-15-2014, 11:13 AM   #4
A3r0pusH
A3r0pusH's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Is there no keyhole for the trunk? Just checked and the OEM trunk of the FRS has a keyhole to open the trunk.
A3r0pusH is offline   Reply With Quote
Old 04-15-2014, 12:23 PM   #5
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
I don't think the issue is getting into the trunk, I think the issue is getting the seats folded down from inside the trunk.
It sounds like the GT86 doesn't have the release straps from the factory, and instead has the seat release inside the car. If he or she removed their door keyhole, there would be no way to get into the car in the cases originally mentioned since there aren't release straps in the trunk.
fourvalleys is offline   Reply With Quote
The Following User Says Thank You to fourvalleys For This Useful Post:
strat61caster (04-15-2014)
Old 04-15-2014, 04:17 PM   #6
MasterofNim
Thank you! That is what I'm after! I'll let you guys know how I go at the dealer.
And fourvalleys is correct. The issue is getting to the cabin when you can't open the doors. We can unlock the rear seat from in the cabin but not from in the trunk.
Old 04-15-2014, 07:54 PM   #7
extrashaky
Drives: 2014 BRZ Limited
Why?
Old 04-16-2014, 05:32 AM   #8
MasterofNim
Originally Posted by extrashaky View Post
Why?
Because it is 99.99999% redundant. I never use it and would rather not look at it. It is so much better without it. Of course there is that one time that you require physical key access and that is what I am attempting to ensure.
Update.
I have to buy the the entire assembly which is $350. So I am going to have to make something up.
Thank you very much for your help, especially supramk4.
Old 04-16-2014, 08:09 AM   #9
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
How did you go about replacing keyhole, Does what you replace the keyhole with just cover it?
On the some Lexus, they keyhole is covered. And during emergencies you need to pop off the cover to access the physical keyhole underneath. But that kind doesn't help you now, you would have to put they key mechanism back in the door, and find a place that has parts that has handle covers
FiRStsc10n is offline   Reply With Quote
Old 07-04-2014, 07:58 PM   #10
MasterofNim
[QUOTE=FiRStsc10n;1676076]How did you go about replacing keyhole, Does what you replace the keyhole with just cover it?
On the some Lexus, they keyhole is covered. And during emergencies you need to pop off the cover to access the physical keyhole underneath. But that kind doesn't help you now, you would have to put they key mechanism back in the door, and find a place that has parts that has handle covers[/QUOTE
The key hole barrel is totally removed and is replaced with the same cover that is on the passenger side. I just ordered one of those and simply replaces the key hole part.
Old 07-05-2014, 06:11 AM   #11
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Wow.... anyone have this for the GT86 rather than FRS (to have the underpanels, exhaust tips, keyless, ....)? Also any PDF of these hanging around?
Harvey is offline   Reply With Quote
DIY: Shrader Performance Rear Seat Delete Kit & Rear Seat Removal PoorMansRacing DIY (Do-It-Yourself) Guides 98 10-10-2023 04:51 PM
Broken Rear Seat Release Tank Issues | Warranty | Recalls / TSB 11 07-23-2017 07:44 PM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
FS: TRS Tow Straps!!! sonnydelight Exterior Parts (Aero, Lighting, Etc.) 6 07-26-2013 01:30 PM
Rear Seat Release Buttons NedVargar Issues | Warranty | Recalls / TSB 7 08-29-2012 01:43 PM
