Old 04-13-2014, 04:32 PM   #1
tr3o
End link jarring/clunk (front)
So I installed BC coilovers and with the endlinks supplied I noticed they were tapping the LCA, now that I have shortened them ( about as short as they go) I seem to have a jarring/clunk noise at slow speed over bumps, freeway seems to ride fine. I'm guessing it's the endlinks cause the noise sounds low and not like the typical loose strut nut clunk and I checked it.
Is there a recommended length for endlinks? (Lowered about 2")
Damper set to a 1 full rotation from softest.
Thanks!
tr3o is offline   Reply With Quote
Old 06-08-2014, 12:57 PM   #2
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Ill bring this back from the dead. Not a coilover install here but Eibach prokit springs and Bilestein strut install. I've got a clunk from the front but mainly its the loudest when I'm turning and off camber (entering a parking lot, turning over a speed bump).
I've taken my front wheel off, loosened up the strut from the caliper assembly and raised and lowered everything with the wheel turned and straight. I pulled everything as hard as I could but could not replicate a clunk anywhere. No visable signs of rubbing or wear. Anyone have any ideas?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 06-08-2014, 11:24 PM   #3
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Have you double checked that the nut that secures the shock to the top mount is not loose?
Andreas83 is offline   Reply With Quote
Old 06-09-2014, 12:32 AM   #4
JOSEC
Drives: 2014 Subaru BRZ WRB
I just installed my BC coilovers. I dropped the car about 1 inch and noticed how close the LCA were from the swaybar end links. I drove it and made sure it didn't clunk. Nothing was wrong but for peace of mind I installed the adjustable ones. I shortened them enough so that theres no chance they would hit the LCA. I shortened the other side as well, dropped the car and made sure there was no pre load on the sway bar. It's been almost a week now and I haven't had any problems.
JOSEC is offline   Reply With Quote
Front End link question protpibe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 02-08-2015 10:45 AM
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 05:49 PM
E-Brake clunk? topazsparrow Issues | Warranty | Recalls / TSB 10 07-08-2013 11:23 PM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 09:39 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-01-2012 11:45 PM
