Old 04-13-2014, 06:27 AM   #1
350matt
Drives: toyota mr2/ Toyota GT86
Steering rack off now TC kicks in all the time?
Gents
I had to remove my steering rack to fit some new mounting bushes and while I carefully marked the steering input shaft before disconnecting the column knuckle and it all went back in the same place
the car does track straight and true but I'm certain that the TC light never used to flash as much as it does now
looking at the steering angle logged value on ECUtek it shows that the dead ahead position is reading about 2-5° so I'm suppose that's the problem
So I think that I must have the steering out by 1 spline or so
your thoughts?
350matt is offline   Reply With Quote
Old 04-13-2014, 01:43 PM   #2
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Yeah...sounds like you're off a spline or two. I've had my rack in and out twice, don't ask why, and haven't had the TC issue you're speaking of. But if Ecutek is logging 2-5 degrees of steering angle straight ahead there may be an issue. Did you get her realigned after reinstalling the rack as well?
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 04-13-2014, 03:32 PM   #3
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
This is probably a good idea. The good machines (like the one we use Hunter Hawkeye Elite) will connect to the ECU and can reset that during the alignment.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 04-15-2014, 10:29 AM   #4
350matt
Cheers for that
I'II get it booked in at Toyota then for a 4 wheel set-up and steering wheel calibration
looks like this car is bit particular about this
PERRIN Steering Rack Lockdown PERRIN_Mladen Brakes, Suspension, Chassis 30 06-10-2018 05:45 PM
Steering rack diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-07-2014 12:12 AM
TiC steering rack bushin sale!!! Turn in Concepts Brakes, Suspension, Chassis 0 07-23-2013 11:44 AM
Steering rack bushing weekend sale Turn in Concepts Brakes, Suspension, Chassis 0 05-17-2013 07:24 PM
GROUP BUY - TiC BRZ/FR-S steering rack bushings Turn in Concepts Groupbuys 186 03-19-2013 08:04 AM
