Old 04-12-2014, 09:06 PM   #1
bfsnail
bfsnail's Avatar
Sportlines before and after camber correction
Just wanted to throw this out there for anyone who may have been in the same boat as me.
I installed Eibach sportlines a few months ago along with some larger wheels and tires. I loved the way the car looked but honestly I didn't like the way the handling had changed. It had significantly less rear traction under power and it felt like it understeered while just taking turns around town. I think I had something like -.1 camber in the front and -1.7 or so in the rear with zero toe on both. Anyways, it was a love (looks) hate (handling) sort of relationship.
I finally got around to installing SPC camber bolts in front and lower control arms in the rear and got another alignment with -1.3 camber and 0 toe in the front and -1.2 camber and +0.1 toe in the rear.
I fell back in love with the car While its probably still far from perfect, its loads better than what it was and I'm pretty sure I like it more than when it was stock (although that was awhile ago...)
Either way, if you are in the same situation I was in with the Sportlines, you might try to get some other suspension bits to make the car feel the way it should (IMO).
That's it. Carry on.
bfsnail is offline   Reply With Quote
The Following User Says Thank You to bfsnail For This Useful Post:
SkAsphalt (04-13-2014)
Old 04-13-2014, 11:24 AM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I'm in the same boat you were in. I have -0.5 in the front, -2.1 in the rear. Any tips on how you installedthe camber bolts? I have the whiteline 16mm in the upper bolt
malubawla is offline   Reply With Quote
Old 04-16-2014, 01:58 PM   #3
bfsnail
bfsnail's Avatar
The SPC bolts are designed for the top bolt and I'm not entirely sure about the whiteline bolts. Either way, you should be able to get more than -0.5 in the front with just bolts. On the SPC, I needed to put the tab away from the car for max negative camber. Maybe you have the tab facing the wrong way?
Old 04-16-2014, 04:23 PM   #4
RobertB
Drives: 2013 Subaru BR-Z
According to the SPC instructions, the camber bolts are for the lower hole.
http://www.spcalignment.com/instruct...05-INS_WEB.pdf
RobertB is offline   Reply With Quote
Old 04-17-2014, 02:50 PM   #5
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
i have the tap facing the inner part of the car
the bolt are 16mm, wont fit in the bottom holes. i think the whiteline are the same as the spc, KC416 i think was the part number
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Camber correction derek9010 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-22-2014 09:35 PM
Enjuku Racing - Whiteline Control arm inner bushing (camber correction) Enjuku Racing Brakes, Suspension, Chassis 0 04-11-2013 11:21 AM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 12:20 AM
