Sportlines before and after camber correction
Just wanted to throw this out there for anyone who may have been in the same boat as me.
I installed Eibach sportlines a few months ago along with some larger wheels and tires. I loved the way the car looked but honestly I didn't like the way the handling had changed. It had significantly less rear traction under power and it felt like it understeered while just taking turns around town. I think I had something like -.1 camber in the front and -1.7 or so in the rear with zero toe on both. Anyways, it was a love (looks) hate (handling) sort of relationship. I finally got around to installing SPC camber bolts in front and lower control arms in the rear and got another alignment with -1.3 camber and 0 toe in the front and -1.2 camber and +0.1 toe in the rear. I fell back in love with the car Either way, if you are in the same situation I was in with the Sportlines, you might try to get some other suspension bits to make the car feel the way it should (IMO). That's it. Carry on. |
| The Following User Says Thank You to bfsnail For This Useful Post: | SkAsphalt (04-13-2014) |
#2 |
poor man's evora
Drives: Turbod BRZ
I'm in the same boat you were in. I have -0.5 in the front, -2.1 in the rear. Any tips on how you installedthe camber bolts? I have the whiteline 16mm in the upper bolt
#3 |
The SPC bolts are designed for the top bolt and I'm not entirely sure about the whiteline bolts. Either way, you should be able to get more than -0.5 in the front with just bolts. On the SPC, I needed to put the tab away from the car for max negative camber. Maybe you have the tab facing the wrong way?
#4 |
Drives: 2013 Subaru BR-Z
According to the SPC instructions, the camber bolts are for the lower hole.
http://www.spcalignment.com/instruct...05-INS_WEB.pdf |
#5 |
poor man's evora
Drives: Turbod BRZ
i have the tap facing the inner part of the car
the bolt are 16mm, wont fit in the bottom holes. i think the whiteline are the same as the spc, KC416 i think was the part number
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 10:09 PM |
| Camber correction | derek9010 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 02-22-2014 09:35 PM |
| Enjuku Racing - Whiteline Control arm inner bushing (camber correction) | Enjuku Racing | Brakes, Suspension, Chassis | 0 | 04-11-2013 11:21 AM |
| WORKS Rear Upper Control Arm Bushing - Inner Camber Correction | 86_ZN6 | Brakes, Suspension, Chassis | 0 | 02-06-2013 12:20 AM |
