Old 04-10-2014, 11:43 PM   #1
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Loud Buzzing Noise - Car Not Running
I went out to my garage tonight and heard a loud buzzing noise coming from my BRZ. Investigated it a bit and found that it was coming from the rear, possibly more toward the passenger side. My only thought was that possibly the fuel pump was running or a relay back there was chattering.
The car hasn't been started in over 5 hours, so I'm a bit concerned why this is happening and am a bit worried about a possible fire hazard. It stopped shortly after I took this video. Phone cam doesn't pick the noise up well away from the car, but you can hear it clear as day. Picked up great from under.
[ame="https://www.youtube.com/watch?v=hRRfew-WWxM"]https://www.youtube.com/watch?v=hRRfew-WWxM[/ame]
Apex_BRZ is offline   Reply With Quote
Old 04-10-2014, 11:57 PM   #2
HapaHaole
Drives: Grocery cart
That's normal, its your EVAP system doing its test.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 04-11-2014, 12:01 AM   #3
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
This ^^^
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 04-11-2014, 12:08 AM   #4
Apex_BRZ
Good to hear.
I've never heard this on any other car before. Can anyone tell me a bit more about it?
Old 04-11-2014, 12:40 AM   #5
HapaHaole
Originally Posted by Apex_BRZ View Post
Good to hear.
EVAP is the system that checks and monitors the fuel vapors in your fuel tank. IT captures the fumes into a charcoal canister which is later send to your engine to be used as fuel. To test the fuel system to make sure there is No leaks the system applies a vacuum pump to the tank while making it air tight. The noise you hear is the pump applying very small amount of vacuum to the tank to check for leaks.
Every car has this, just different versions. New systems have a dedicated vacuum pump, and that's what you are hearing.
if you ever had a newer car and left the gas gap loose your check engine light turn on, well its because that test failed.
Old 04-11-2014, 01:12 AM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's in your owner's manual. Read it.
-alex
Old 04-11-2014, 09:18 AM   #7
Apex_BRZ
-alex
And avoid a lengthy discussion with you wonderful fellas? Don't be ridiculous.
Old 04-13-2014, 05:00 PM   #8
ChrisxChainsaw
ChrisxChainsaw's Avatar
Drives: 2013 Scion FRS
My motorcycle used to do that (2013 636) I was like dafuq?!
ChrisxChainsaw is offline   Reply With Quote
Buzzing noise from rear pass wheel area when parked pszuvela Issues | Warranty | Recalls / TSB 7 12-11-2013 12:36 AM
FR-S Loud Engine Noise White0utFrs Issues | Warranty | Recalls / TSB 15 09-20-2013 08:28 PM
Buzzing speakers FRS_Sovereign Electronics | Audio | NAV | Infotainment 8 06-09-2013 02:41 PM
buzzing in steering wheel wbsrazzle Issues | Warranty | Recalls / TSB 2 05-15-2013 09:05 PM
buzzing noise from steering wheel FR-S :DK Scion FR-S / Toyota 86 GT86 General Forum 1 10-07-2012 01:52 AM
