Old 04-10-2014, 09:59 PM   #1
SavingManuals
Team Legacy
SavingManuals's Avatar
Drives: LS swapped FRS, 5 speed
Need some help building my f.i charge pipe
Hey everyone,
I ordered an fa20club turbo kit about 4 months ago and parts have been coming in slow and I am sick of bugging this guy to ship my already paid for products. I don't have time to wait for this guy anymore as racing season is starting soon, so I'm forced to build my own upper charge pipe. I have everything but the upper charge pipe and a couple other non crucial parts. Keep in mind I am injecting water/meth and trying to keep it 4-5" before the throttle body.
I just ordered my bov vband flange, a fitting to screw my water/meth nozzle into, and I'm making my own maf sensor flange. However due to limited space in the pipe, I am thinking I have to put my maf sensor right BEFORE a bend. Will this still cause turbulence even tho it's not after the bend? The blow off valve would be located roughly 8" from the maf sensor back down the pipe. Would this also cause an issue?
Thanks everybody in advance.
Here's a attached pic of what I was thinking. It's so tight for room and straight piping its crazy. Name:  ImageUploadedByTapatalk1397181490.982407.jpg
Team Legacy
@timeattackrob
@team_legacycc
SavingManuals is offline   Reply With Quote
Old 04-10-2014, 10:13 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Before is certainly better then after. This is why I really don't like MAF's they can be touchy, SD allows much more freedom. If you are concerned you could put a honeycomb in the pipe.
And if you want one I have a whole bunch of aluminum MAF flanges.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
SavingManuals (04-10-2014), Sportsguy83 (04-10-2014)
Old 04-10-2014, 10:20 PM   #3
SavingManuals
Team Legacy
Okay perfect, I know they are so touchy. Want as accurate of a reading as possible.
And man it would save me a load of time, could you email me at rob_grip@hotmail.com? Il buy one of those flanges off of you for sure!
Team Legacy
@timeattackrob
@team_legacycc
Old 04-11-2014, 12:11 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I see no issues with that other than the same issue that some of us have had utilizing the TiAL Q BOV that close to the MAF sensor. Just make sure the BOV stays closed so that it can't create any turbulance in the air going to the MAF in high vacuum conditions and you will be fine.
The Following User Says Thank You to King Tut For This Useful Post:
SavingManuals (04-11-2014)
Old 04-11-2014, 01:27 PM   #5
SavingManuals
Team Legacy
Thanks a lot King Tut. Il definitely look into that.
Team Legacy
@timeattackrob
@team_legacycc
Old 04-11-2014, 01:57 PM   #6
SavingManuals
Team Legacy
I just clued into something that you said as I read it walking out of work. I am using the turbosmart race port bov. I didn't pick the tial. Does the turbosmart still have the same problem?
Team Legacy
@timeattackrob
@team_legacycc
Old 04-11-2014, 02:30 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It works the same way as the TiAL Q utilizing a spring that you can swap out:
http://www.turbosmart.com.au/wp-cont...t-Oct-2013.pdf
Old 04-11-2014, 02:37 PM   #8
SavingManuals
Team Legacy
Okay awesome thanks man.
Team Legacy
@timeattackrob
@team_legacycc
Do you feel in Charge? LS13 Off-Topic Lounge [WARNING: NO POLITICS] 0 03-28-2014 09:01 PM
Building my FR-S Gillams Scion FR-S / Toyota 86 GT86 General Forum 5 09-06-2013 12:37 PM
Freight charge on Scion FR-S? euroshowoff Scion FR-S / Toyota 86 GT86 General Forum 7 04-25-2013 10:36 AM
would you turbo or super charge your BRZ/FRS? chenshuo Scion FR-S / Toyota 86 GT86 General Forum 45 03-04-2013 10:13 AM
ECU Charge??? DBacon1052 Issues | Warranty | Recalls / TSB 12 09-18-2012 11:53 PM
