Old 04-09-2014, 06:13 PM   #1
Pneub
Drives: Dark Grey BRZ
Rear Brake Upgrade To Match Stoptech Fronts
I currently have Stoptech front brakes and they look and work great but the rear brakes look like shit in comparison. Is there a decent looking rear brake that has equal or better stopping force that I can pull from another car that will match up easily on the BRZ?
Pneub is offline   Reply With Quote
Old 04-09-2014, 06:26 PM   #2
DAEMANO
Time Traveller
http://www.racingbrake.com/Big-Brake...ar-p/2315k.htm
Old 04-09-2014, 06:37 PM   #3
Pneub
Originally Posted by DAEMANO View Post
I'm not looking to spend a lot of money on the rear brakes. I'd rather pull used ones off another vehicle and just resurface the rotors and new pads.
Old 04-09-2014, 07:12 PM   #4
DAEMANO
Time Traveller
I don't know where you would find a direct bolt on rear rotor from another vehicle. In other threads looking for the same there have been mostly dead ends.
The problem you'll run into with most rears are keeping the stock emergency brake working properly. The rotors from this kit retain the stock e-brake function and IIRC fit the stock caliper. I've read that the rotors can be ordered as a part (that is to say without the full kit). Later, you could choose to add the forged calipers if that suits your fancy.
Still, another thread about this might just turn up a new answer. Who knows. I'm subscribed just in case.
Old 04-09-2014, 07:28 PM   #5
Pneub
Cool thank you for the info. I'm really just looking to make the rear end look better. I know it's superficial but it would look much better if the front and rear matched. But I don't care enough to spend serious money. If I was going to drop that much I'd just get the Stoptech rears but there's no way to justify it for the type of driving I do.
Old 04-10-2014, 07:47 AM   #6
wparsons
wparsons's Avatar
Arguably there was no justification to spend money on stoptech fronts either
flickr
The Following User Says Thank You to wparsons For This Useful Post:
SportInjected (04-10-2014)
Old 04-10-2014, 08:14 AM   #7
argonaddict
Drives: 2005 PSM STI
Sti brembo rears paint matched to the stoptechs?
argonaddict is offline   Reply With Quote
Old 04-10-2014, 10:35 AM   #8
subyboy
Drives: 13' swp brz limited
im selling 05 rear sti brembo calipers is you are interested just leave me a pm
subyboy is offline   Reply With Quote
Old 04-10-2014, 12:30 PM   #9
mrk1
Drives: Sterling BRZ Ltd
I think it was Carolina Dyno that was working on a StopTech rear kit but probably not a cheap fix for cosmetic points.
I have just the StopTech front kit as well, sure it doesn't look as good as a full kit but they do a awesome job as it is so I cant justify the price jump to a 4 wheel setup.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-10-2014, 12:39 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You could get 2 pot oem from the 06-07 wrx. Cheaper than a bbk but looks better.
I think one of the stx build threads has that combo
Sent from my LT30at using Tapatalk
SOLD: Stoptech Sport Kit Front and Rear Brake upgrade johnb831 Brakes, Suspension, Chassis 1 01-05-2014 10:20 PM
Swapping rear brakes to match Stoptech BBK Pneub Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-17-2013 02:01 PM
StopTech Stainless Brake Lines (Front and Rear) for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 1 07-19-2012 01:41 PM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 10:58 AM
