Southern California SoCal
Old 04-09-2014, 03:47 PM   #1
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Ohlins Road and Track special! $3115 Installed!
Hi Everyone!
Since we are so in love with the Ohlins we want to give back to the community with this amazing option!! These are the perfect street and track coilovers! They are individually height adjustable, and also sprung perfectly for a smooth ride that will not chatter your teeth out! When you are on track the dampening is able to stiffen up to the performance that you need and accommodate all apexes that you will be hitting!
With the purchase of a set of Ohlins Road and Track Coilovers we will install them on your car!
Price: $3115+tax(with install)
This image has been resized. Click this bar to view the full image. The original image is sized 1920x1080.This image has been resized. Click this bar to view the full image. The original image is sized 1920x1080.This image has been resized. Click this bar to view the full image. The original image is sized 1920x1080.
Check out this detailed explanation of the coilovers here!
Check out these reviews!
http://www.ft86club.com/forums/showthread.php?t=48679
Figure 1: (Compression flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the compression ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the compression ports in the DFV, increasing comfort. Figure 2: (Rebound flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the rebound ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the rebound ports in the DFV, maintaining tyre contact with the road.
Figure 3: (Vehicle – no DFV) Without DFV the oil can not flow through the piston quickly enough on the rebound stroke after hitting a bump, so the tyre is not able to stay in contact with the road.
Figure 4: (Vehicle – DFV technique) The DFV valve opens, letting the oil flow quicker through the piston on the rebound stroke after hitting a bump, enabling the tyre to stay in contact with the road.
Thanks,
Mike
Corner3garage is offline   Reply With Quote
Old 04-10-2014, 05:02 PM   #2
Corner3garage
Drives: FR-S & BRZ
Bump
Old 04-11-2014, 07:57 AM   #3
Ms. FR-S
Drives: 2013 Scion FR-S, 1993 Mazda RX-7
*drool*
Bumpity
Ms. FR-S is offline   Reply With Quote
The Following User Says Thank You to Ms. FR-S For This Useful Post:
Corner3garage (04-14-2014)
Old 04-14-2014, 08:06 PM   #4
Corner3garage
Drives: FR-S & BRZ
Originally Posted by Ms. FR-S View Post
*drool*
Bumpity
Drool indeed!
We recently did this to a 350z!
The Following User Says Thank You to Corner3garage For This Useful Post:
Ms. FR-S (04-14-2014)
Old 04-14-2014, 08:28 PM   #5
retrosmiths
Drives: Scion FR-S Whiteout
Price includes alignment?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-14-2014, 08:47 PM   #6
Corner3garage
Drives: FR-S & BRZ
Alignment will be separate and based on which adjustable arms you have.
Old 04-15-2014, 04:09 PM   #7
Corner3garage
Drives: FR-S & BRZ
Completely unmatched in quality and damper technology!
Old 04-23-2014, 02:41 PM   #8
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 04-24-2014, 03:09 PM   #9
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 04-25-2014, 03:53 PM   #10
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 04-28-2014, 03:33 PM   #11
Corner3garage
Drives: FR-S & BRZ
Ohlins is the only single adjustable I would use!
Old 04-29-2014, 12:56 PM   #12
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 04-30-2014, 02:26 PM   #13
Corner3garage
Drives: FR-S & BRZ
Ohlins!
Old 05-01-2014, 02:32 PM   #14
Corner3garage
Drives: FR-S & BRZ
Outright the best single adjustable coilover I can imagine!
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
FS: Ohlins Road And Track DFV Coilover in Socal mtsui Brakes, Suspension, Chassis 5 03-27-2014 11:02 PM
Ohlins Road and Track special! ***Free install and alignment w/purchase!*** Corner3garage Southern California 23 02-11-2014 06:02 PM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
