Southern California SoCal
Old 11-15-2013, 03:18 PM   #1
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Ohlins Road and Track special! ***Free install and alignment w/purchase!***
Hi Everyone!
Since we are so in love with the Ohlins we are having a special!! These are the perfect street and track coilovers! They are individually height adjustable, and also sprung perfectly for a smooth ride that will not chatter your teeth out! When you are on track the dampening is able to stiffen up to the performance that you need and accommodate all apexes that you will be hitting!
With the purchase of a set of Ohlins Road and Track Coilovers we will install and Align your car for FREE!
Price: $3766+tax(with free install and alignment)
Check out this detailed explanation of the coilovers here!
Check out these reviews!
http://www.ft86club.com/forums/showthread.php?t=48679
Figure 1: (Compression flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the compression ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the compression ports in the DFV, increasing comfort. Figure 2: (Rebound flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the rebound ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the rebound ports in the DFV, maintaining tyre contact with the road.
Figure 3: (Vehicle – no DFV) Without DFV the oil can not flow through the piston quickly enough on the rebound stroke after hitting a bump, so the tyre is not able to stay in contact with the road.
Figure 4: (Vehicle – DFV technique) The DFV valve opens, letting the oil flow quicker through the piston on the rebound stroke after hitting a bump, enabling the tyre to stay in contact with the road.
Thanks,
Mike
Corner3garage is offline
Old 11-20-2013, 04:05 PM   #2
Corner3garage
Drives: FR-S & BRZ
PM's replied!
Old 11-21-2013, 06:43 PM   #3
Corner3garage
Drives: FR-S & BRZ
5% of sales profits will be donated to the victims of the Haiyan Typhoon.
Old 11-29-2013, 06:46 PM   #4
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 12-04-2013, 07:09 PM   #5
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 12-09-2013, 01:49 PM   #6
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 12-09-2013, 02:33 PM   #7
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Well damn, with all those "bumps" I might actually need that DFV!
Manic is offline
Old 12-10-2013, 03:35 PM   #8
Corner3garage
Drives: FR-S & BRZ
You live in california?
In that case, we all need DFV!
Old 12-10-2013, 03:51 PM   #9
Manic
Is not fast.
Manic's Avatar
Preach.
Manic is offline
Old 12-17-2013, 02:09 PM   #10
Corner3garage
Drives: FR-S & BRZ
We have worked with PCV and now DFV! Both are great but DFV definitely takes it to the next level!
Old 12-23-2013, 05:47 PM   #11
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 12-31-2013, 02:58 PM   #12
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 01-02-2014, 01:28 PM   #13
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 01-06-2014, 12:50 PM   #14
Corner3garage
Drives: FR-S & BRZ
Bump!
Ohlins Road & Track for FRS/BRZ suspension install/review thread mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 628 01-30-2024 05:16 AM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
