Old 04-08-2014, 08:28 PM   #1
stueck9356
Drives: 2015 VW GTI SE
OFT quirk
I just got my OFT and immediately flashed their newest stage 1 tune. Aside from small things in my signature, I haven't done any mods.
This weird quirk happens at 4k. There is a hiss from the engine, sounds similar to a blow off valve letting out a small amount of pressure. I can make it happen consistently when over ~50% throttle. Does anyone else have this issue or can explain it?
Sent from my Nook HD using Tapatalk
stueck9356 is offline   Reply With Quote
Old 04-08-2014, 09:07 PM   #2
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
its the exhaust timing. very aggressive right at 4k.
Grymm86 is offline   Reply With Quote
Old 04-08-2014, 09:36 PM   #3
stueck9356
So perfectly safe?
Old 04-08-2014, 09:40 PM   #4
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
So perfectly safe?
Yes of course.
Old 04-08-2014, 09:53 PM   #5
stueck9356
okay, thanks for the fast response!
You wouldn't mind explaining why such aggressive timing at 4k? is it for the dip?
Old 04-08-2014, 09:59 PM   #6
steve99
Yes I believe it is to reduce torque dip. If you change to UEL headers it does not have to be as aggressive so noise is eliminated.
Old 04-08-2014, 10:05 PM   #7
Shiv@Openflash
Drives: 2013 FRS
As far as valve timing goes, it's hard to differentiate between "aggressive" or not. It's not like ignition timing in that respect. In the case is the OTS maps, valve timing goes through a rather large swing to minimize the torque dip. With the stock VVT mapping, the change is more gradual making it harder to perceive.
Old 04-08-2014, 10:46 PM   #8
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Read this/watch this.
http://www.ft86club.com/forums/showthread.php?t=59475
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 04-10-2014, 03:39 PM   #9
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Is there any way to tune it out? Honestly I'd rather deal with the dip more than have my car sound like it's going to blow.
l0aded is offline   Reply With Quote
Old 04-10-2014, 04:49 PM   #10
phrosty
The first time I heard the sound I was alarmed --- maybe my intake covers it up just enough but I feel like I'm the only one who likes it.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 04-10-2014, 05:37 PM   #11
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Here are two of my videos of this noise. Totally normal and safe.
[ame="https://www.youtube.com/watch?v=nKCK_zViHks"]4000k RPM Note Change on e85 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=BwKDJyYLggo"]4000rpm Note Change - YouTube[/ame]
Luckrider is offline   Reply With Quote
Old 04-10-2014, 06:17 PM   #12
Shiv@Openflash
Drives: 2013 FRS
I have yet to hear of an engine make that sounds before blowing up
Old 04-11-2014, 11:45 AM   #13
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Count me in as a fan as well! The first time my wife heard it she was very curious as to what it was. Of course I had to tell her it was AVCS kicking in, yo!
In reference to the tip-in knock thread posted prior, this noise has NOTHING to do with knock. Knock sounds completely different, and for anyone who spent significant time around K-series, 2zz or other motors that are high comp and as sensitive to fuel grade as ours are, you'd know the difference. I am astounded sometimes by the amount of mechanical hypochondriacs here. Just drive it and enjoy it
Sent from my XT1056 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 04-11-2014, 11:53 AM   #14
Shiv@Openflash
Drives: 2013 FRS
mechanical hypochondracs
There is a degree of truth to that. I can hear a knock from 40 feet away. But my ears completely ignore the intake noise at 4000rpm because I've heard it before in so many cars, that it falls into the list of acceptable and safe noises
I start at Quirk Subaru this week! Turbowned New England 22 10-23-2012 10:54 AM
