Old 04-08-2014, 12:50 AM   #1
Goodmanner
10 Series TRD
Goodmanner's Avatar
Drives: 2013 FRS 10 Series, 2013 IS250
Leaking Shock Abosrber
My car is currently at around 5400 miles and I noticed some sort of leakage coming from the rear driver side. At first I thought it might've been a leaking exhaust but it turns out to be from the shock absorber.
Has anyone else experienced this issue?
Goodmanner is offline   Reply With Quote
Old 04-08-2014, 12:52 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
rule out leaking exhaust vs leaking shock absorber
wut?
Old 04-08-2014, 12:57 AM   #3
Goodmanner
10 Series TRD
Goodmanner's Avatar
wut?
I'm not too technical of a person when it comes to cars so bear with me. What I first noticed on the drive way were wet stains. My initial conclusion was that it might be coming from the exhaust (as the stain was near the area). Anyway, I wiped it with my finger and it was this rather clear oil. I had a friend of mine come over to take a gander and he confirmed that it was coming from the shock absorber.
Anyway I'm going to be taking this to the dealership tomorrow but I wanted to see if anyone else had similar issue(s) with this.
Thanks for your reply, however.
Old 04-08-2014, 12:59 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
If it is actually an oil there is no way it is from the exhaust, I agree with taking to dealer if it is an oil and not just water
Old 04-08-2014, 01:38 AM   #5
humfrz
I haven't read about any leaking shocks on these cars.
However, whatever is leaking back there ..... it shouldn't be.
Yep, best have it checked out.
I hope it's minor.
humfrz
Old 04-08-2014, 07:34 AM   #6
sshole
If your shock is leaking, you should be able to tell pretty easily. Lift up right rear corner of the car, grab a white paper towel, wipe the shock as best you can through the coils of the spring. Do you see oil? If yes, go to the dealership and get a new one. If no, it's likely not your shock.
sshole is offline   Reply With Quote
Old 04-08-2014, 11:15 AM   #7
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Are you lowered on springs?
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 04-08-2014, 11:19 AM   #8
Goodmanner
10 Series TRD
Goodmanner's Avatar
Hello, yes I am. I have the eibach pro kit installed. I've had it installed for well over 3 months and never had an issue.
Old 04-08-2014, 11:45 AM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
In that case you are SOL dealer isn't going to replace that for you. Buy some konis or bilsteins to replace
Old 04-08-2014, 12:36 PM   #10
Goodmanner
10 Series TRD
Goodmanner's Avatar
I dropped it off this morning and am waiting to hear back from them. Hopefully the Warranty Gods will grace me with their presence.
Old 04-08-2014, 01:15 PM   #11
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
You do now!! An upgrade is in order, I anticipate this when I lower my own! I'd like to put KYB adjustable struts on, if they make them for our cars...
Wolfking is offline   Reply With Quote
Old 04-08-2014, 01:29 PM   #12
Goodmanner
10 Series TRD
Goodmanner's Avatar
I was hoping the stock would at least last more than a few thousand miles.. I am still waiting for the dealership to give me a call back on the status.
Old 04-08-2014, 01:30 PM   #13
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Definitely let us know if they warranty the shock w/ the Eibachs installed.
Originally Posted by humfrz
I'm old and lazy
Old 04-08-2014, 01:33 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
If they warranty it you better go play the lotto
Oil Leaking?? tonytduc Issues | Warranty | Recalls / TSB 371 11-13-2016 07:14 PM
Oil leaking? grgonium CANADA 7 07-30-2013 04:08 AM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 04:15 PM
