Old 04-05-2014, 08:34 PM   #1
dad&sonFRS
Drives: Firestorm FR-S
Winjet headlights pointing too low
I just installed my winjet headlights, and the the headlights seem to be pointing to the group. When driving at night the lights only light up a bit of the road in front of me, nothing like the oem lights. Is it normal for the light to be pointing to the ground?
dad&sonFRS is offline   Reply With Quote
Old 04-05-2014, 08:37 PM   #2
Frs32907
Drives: Asphalt grey, manual Fr-S
There are adjusters behind the headlights its a a metal circle with a bolt. Just need the right size socket wrench and your good . Give yourself some space from a wall and adjust them
Frs32907 is offline   Reply With Quote
Old 04-05-2014, 10:00 PM   #3
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
It's an 8mm bolt. Line up about 20-25 feet from a wall and start cranking till you get them where you want them.
C130NAV is offline   Reply With Quote
Old 08-10-2015, 01:23 PM   #4
WhiteKnight86
WhiteKnight86's Avatar
Drives: 2014 Whiteout FR-S
I'm glad there's a way to adjust it.
I just installed these over the weekend. I only did a simple test of turning them on. Once I started driving at night, the light was pointed way too low. I could not see anything further than 6ft away from my car. I'm glad you can adjust it because I thought I bought a dud.
WhiteKnight86 is offline   Reply With Quote
Old 08-10-2015, 07:26 PM   #5
G-awesome
Drives: 2015 Firestorm Scion FRS
you should've seen mine when I installed it...my left headlight was 45 degrees to the left. I completely forgot to adjust it when I bolt it on. Thank god I didn't drive at night or it wouldve aimed right in the faces of oncoming traffic...
G-awesome is offline   Reply With Quote
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
DIY Retrofit Winjet headlights post_break DIY (Do-It-Yourself) Guides 6 07-15-2014 12:13 AM
Has anyone modified the winjet headlights to keep led's on? 86black Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 12:42 AM
FS: Winjet Chrome Headlights civicdrivr Exterior Parts (Aero, Lighting, Etc.) 6 01-16-2014 11:33 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
