Old 04-05-2014, 12:21 AM   #1
frstn
frstn's Avatar
Drives: 2013 FRS
dash speaker problems
so I've been reading the forums and seems like a lot of people have been having problems with aftermarket ones fitting right. anybody find some that fit flush? no modification? should I be looking for 3.5 or 4" speakers for the dash?
frstn is offline   Reply With Quote
Old 04-07-2014, 09:51 PM   #2
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Most any 3.5" will fit just fine in the dash with no modifications required to the dash mounting itself. You may need to use some over sized washers if you wish to use the stock bolt locations however. I am running Infinity Reference 3002cfx in the dash and I used the larger washer method. I then re-pinned in a generic aftermarket speaker adapter using the OEM connector making my own plug and play setup requiring no cutting of the stock harness.
mines13 is offline   Reply With Quote
Old 04-08-2014, 09:23 PM   #3
frstn
frstn's Avatar
Drives: 2013 FRS
okay thanks buddy
Old 04-10-2014, 09:29 PM   #4
Moletheus
Moletheus's Avatar
Drives: Raven 2014 FR-S
I put Infinity Kappa 4"s in the dash:
[ame="http://www.amazon.com/gp/product/B0018SH4TS/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1"]Amazon.com: Infinity 429I 150W (Peak) 4 -Inch 2-Way Speaker (Pair): Car Electronics[/ame]
They fit snugly around the sides but the magnet hits the air duct on both sides and leaves a 1/2" gap. I used a pencil style dremel and carefully cut out the duct just enough to let the speakers sit all the way down then covered the hole with sound deadening material. Works well and sounds 100% better than stock. Especially with plenty of power.
Moletheus is offline   Reply With Quote
Old 04-30-2014, 02:45 PM   #5
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
What exactly do you mean by this?
Prog is offline   Reply With Quote
Old 05-09-2014, 05:24 PM   #6
Purity999
Drives: 14 WRB BRZ Limited
Crutchfield sells a harness for the dash speaker, this is what I used.
http://www.crutchfield.com/p_1207104...71042&skipvs=T
Purity999 is offline   Reply With Quote
Old 05-13-2014, 12:09 PM   #7
mines13
mines13's Avatar
I bought 3 sets of the door speaker plug and play harness. I de-pinned a set of the door speaker harness and the OEM speaker connector plug from the OEM speaker in the dash. I transferred that connector to the set of door speaker harness' I bought to make it a plug and play affair with the aftermarket speakers. Once my amp shows up I will post pictures and info on my whole installation.
The Following User Says Thank You to mines13 For This Useful Post:
Prog (05-13-2014)
Midrange speaker in dash? yomchi1989 AUSTRALIA 59 10-15-2022 03:39 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 04:39 PM
Removing dash speaker grill eckoflyte AUSTRALIA 2 01-19-2013 06:26 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
