Ridge Racerrrrrrrrr
Side marker lights not turning on anymore
Hey guys, just wondering if anyone has run into this problem and if you could give me a hand. Both my left and right side maker lights have stopped working. - They both seemed to have quit at the same time.
Full click of the stalk does give me my proper low beams, turns on my signal lights (as they should) and more weird, activates my fog lights (which are tapped into the side marker lights for activation!) The fog lights were installed last year and everything has been working great since then...so I do not know if it is from that installation or not (simple pinch type tap connector) So could it be
#2 | |
Drives: 2014 Monogram FR-S White MT
I would look at the fog light/parking light connection. The pinch type connector could've cut straight through the wire and now no power is getting to the side marker bulb. |
Drives: '13 Black Subaru BRZ Limited
Check fuse 10 (I think) under the steering column. I believe it's labeled as "tail light fuse" in the manual. That fixed the issue for me, my fuse was fried. I have a BRZ though. Could be a bit different.
#4 | |
Ridge Racerrrrrrrrr
I just thought it was weird because if the fogs still worked, why not the side markers, it's been over a year. I will check the t connector tonight and that fuse. Thanks guys.
Any luck? When my fuse blew the foglights and tail lights did not work. Only the brake lights and main headlight. But as I said before, I have a BRZ so it could be wired a bit different.
Ridge Racerrrrrrrrr
Nope, they still don't work. It is very weird. Kind of put the issue aside while I install my turbo kit though.
| Anybody try VLED side marker lights? | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 03-30-2014 09:17 PM |
| Side marker lights gap | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 03-06-2014 01:42 AM |
| FS: JDM clear side marker lights | ILL_86 | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-02-2014 05:19 PM |
| FS: smoked side marker lights. | NorCal_Guy | Exterior Parts (Aero, Lighting, Etc.) | 46 | 07-14-2013 04:42 PM |
| unplugging side marker lights | BRZPDX | BRZ First-Gen (2012+) — General Topics | 2 | 03-26-2013 11:05 PM |
