Old 04-02-2014, 05:04 PM   #1
D K
Stig's dark passenger
Race seat / SRS Functionality
Hello everyone
Question for those who have replaced the seat with a race seat (and the side airbag):
Since the srs light comes on, will the rest of the airbags still function or are all disabled?
Thanks a bunch
D K is offline   Reply With Quote
Old 04-03-2014, 01:03 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by D K View Post
Hello everyone
Thanks a bunch
It disables the system. Get a resistor to plug into the airbag plug to trick the system into thinking it is hooked up. Google airbag resistor trick and you should be able to find which one to use.
Sent from my LT30at using Tapatalk
Old 04-03-2014, 01:31 AM   #3
D K
Thank you
Old 04-04-2014, 07:15 PM   #4
BRZpower
Its a 3.3ohm resistor for the yellow plug but on passenger side there is also a grey plug that needs signal. So what resistor gets pluged into the grey plug? there has to be a better way than pulling out the seat sensor from the stock seat
BRZpower is offline   Reply With Quote
Old 04-05-2014, 08:50 PM   #5
D K
The gray on both sides is the seat belt chime.
Interestingly. Enough on the druvers side, its a n.o. Curcuit so you can just unplug the plug.
Not so on pass side...
Old 04-05-2014, 11:22 PM   #6
finch1750
finch1750's Avatar
You can have the seatbelt chime disabled via techstream. I did it so it wouldnt go off when my phone was charging and sitting on it.
Old 04-06-2014, 04:18 AM   #7
BRZpower
So why r people pulling out the seat sensor to plug in and put under the seat? I have my passenger seat out but all my airbags are disabled. Yellow plug gets a 3.3ohm resistor. what about the grey one? i dont wanna remove the seat sensor from the stock passenger seat
Old 04-06-2014, 05:01 PM   #8
D K
Gray is seatbelt
Yellow is airbag
86 to Race inaugural Moder Sports Car Race 000 Racing AUSTRALIA 4 05-23-2013 06:22 PM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 08:51 PM
