Old 04-01-2014, 12:24 AM   #1
Eg0
Drives: 2014 Scion FR-S AT - Asphalt
JDM 86 Airbag part number confusion
I'm in the process of ordering the 86 airbag from Japan but have found two different types.
I'm using SU003-03410 as the part number. The results are as follows (the number signs represent japanese characters that I can't decipher):
1 SU003-03410 ------------ 201203-201308 --------- ZN6
2 SU003-03410 ------------ 201308-(nothing) ----- ZN6 - B
The first column is obviously the part number. The second column (I'm assuming) is the model year. The third column (I'm assuming) is the trim/style. If my assumptions are correct, I should get the airbag #2 for the model year 201308 and trim/style zn6-b, correct? Or would it not make a difference?
Just trying to get the correct info before I spend $600+.
Also, sorry for the shitty formatting, couldn't figure out any other way to space it out.
Eg0 is offline   Reply With Quote
Old 04-01-2014, 01:46 PM   #2
DekaMori
DekaMori's Avatar
Drives: RWD
IIRC...there are two (2) different part#s for the airbags, as follows:
SU003-03410 - Single-stage airbag *will require swapping over the detanotor
SU003-03413 - Dual-stage airbag *direct-swap to our FR-S (USDM), since we also use dual-stage
**I know this doesn't exactly answer your question, but thought I should throw the info out there too.
DekaMori is offline   Reply With Quote
Old 04-01-2014, 04:33 PM   #3
Eg0
I'm aware of that but there are two different ones for SU003-03410 as well. There's a Japan-spec one and a euro/overseas one as well.
Thanks anyway
I guess as long as I'm switching the detonator it shouldn't matter which one I get, right?
Old 04-01-2014, 06:39 PM   #4
kbye
kbye's Avatar
Drives: 2014 FR-S
You don't need to swap the detonator if you get SU003-03413, that is the point @DekaMori is trying to make.
Save yourself the trouble and get the dual-stage because they cost the same and look the same anyway.
kbye is offline   Reply With Quote
Old 04-01-2014, 06:54 PM   #5
Eg0
I understand but the only one that I was able to find was the SU003-03410.
Old 04-01-2014, 07:01 PM   #6
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
where are you ordering these from?? Where can i order the dual stage one
ProjectGT86 is offline   Reply With Quote
Old 04-01-2014, 07:03 PM   #7
Eg0
I'm in Japan so I'm ordering from a local shop, I'm not sure where you can find the dual stage
Old 04-01-2014, 07:05 PM   #8
ProjectGT86
do you know where i can order the dual stage one
Old 04-01-2014, 07:06 PM   #9
kbye
kbye's Avatar
Drives: 2014 FR-S
Ah, ok gotcha. The two parts should be identical, but I agree that you should get #2 since it falls within your model year, just to be safe.
Old 04-02-2014, 12:17 PM   #10
DekaMori
DekaMori's Avatar
Drives: RWD
Sorry, not sure...probably need to source from outside JP, as item was intended for export models.
@Eg0 - if you're in jp right now, perhaps may want to check out/swing by upgarage to see if they have any laying around and swap your detonator when you get back state-side
Old 04-02-2014, 06:05 PM   #11
Eg0
@DekaMori
I wasn't able to find any dual-stage. I'm going to go ahead and order the single stage and swap it out when I'm back. Thanks for your help.
Part Number help Sh944 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2013 02:10 PM
what's the part number for this? chenshuo BRZ First-Gen (2012+) — General Topics 11 10-07-2013 11:22 AM
need a part number the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 0 12-12-2012 12:42 PM
I need a part number Bones36 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 05:25 PM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 08:30 PM
