Old 03-31-2014, 01:46 PM   #1
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
DeatschWerks Fuel Pump
Anyone have any experince with the DeatschWerks 265 lph fuel pumps?
C130NAV is offline   Reply With Quote
Old 03-31-2014, 01:54 PM   #2
jamesm
i'd recommend going with full blown's new 485 setup. much better in the long run, especially if you plan to go FI/E85.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
C130NAV (03-31-2014), Ny Brz (03-31-2014)
Old 03-31-2014, 02:06 PM   #3
C130NAV
C130NAV's Avatar
Hmmmmust check that out. I dont plan on E85 now more like 93. Thanks for the tip.
Old 03-31-2014, 02:22 PM   #4
C130NAV
C130NAV's Avatar
Found this.Looks like the DW is E85 compatible to. I guess the other question is what size injector to go with?
Old 03-31-2014, 02:28 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Are you even going forced induction?
Old 03-31-2014, 02:33 PM   #6
C130NAV
C130NAV's Avatar
Yep :-) SBD kit
Old 03-31-2014, 03:08 PM   #7
jamesm
it's compatible, but you'll run out of fuel sooner. e85 requires crazy fuel volume, so if you're planning on making big power it's best to just get the bigger pump and be done with it.
EDIT: just saw you're going with the SBD kit. probably won't need the bigger pump with a turbo that size.
Old 03-31-2014, 03:33 PM   #8
C130NAV
C130NAV's Avatar
@jamesm I plan on staying at 93 for now but may go E85 later. Thanks for the input.
Old 03-31-2014, 04:40 PM   #9
w00t692
Drives: 2008 Civic Si
There are a fuckton of civic's running that pump. It's one of the best OTS pumps around, quieter than any walbro while also putting out a little more fuel volume if necessary. Hell there's some dual pump setups on 8thcivic.com with 2 of these pumps
w00t692 is offline   Reply With Quote
The Following User Says Thank You to w00t692 For This Useful Post:
Old 03-31-2014, 05:01 PM   #10
MAPerformance
Drives: Asphalt FRS
Been running one in my turbo FRS for about 3k miles. Seems to be pretty quiet, and does the job!
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
Old 03-31-2014, 05:14 PM   #11
350matt
Drives: toyota mr2/ Toyota GT86
does this pump just plug into the standard fuel module / cassette?
350matt is offline   Reply With Quote
Old 03-31-2014, 05:30 PM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That is the pump almost everyone is running since it was one of the first available.
Here... http://www.ft86club.com/forums/showthread.php?t=33993
You welcome.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 03-31-2014, 06:00 PM   #13
mike the snake
During my FB turbo install, my shop had problems getting the kit supplied pump to work (didn't get the O-rings and spacer correct) and eventually we put the DW pump in, so far it's been working well.
I'm not going for huge power (eventually 330-350whp) and we don't have E85 around here, so the DW pump is adequate for my uses.
Old 03-31-2014, 06:49 PM   #14
Riggs
Drives: 2001 Mitsubishi Evo
I'd go with a Denso pump if possible.
Riggs is offline   Reply With Quote
Deatschwerks Holiday Power Package Sale!! Fuel pump and injector bundle! Moddiction Forced Induction 0 12-03-2013 05:46 PM
FS: BNIB Deatschwerks DW65c Fuel Pump mfbmike Engine, Exhaust, Bolt-Ons 12 10-25-2013 12:45 PM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 06:29 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
