Big Member
Drives: 2014 FR-S
Do any short shifters improve the downshift to 2nd?
One thing I don't like about the transmission is the downshift to 2nd is pretty awkward, and it's hard to do smoothly and quickly. Wondering if a short shifter would improve that. Like kartboy or something. I know ofc that it would shorten the throw by x%, not not sure about that clunky awkwardness down to 2nd.
Living the dream
Drives: Fensport AVO Turbo GT86
Not sure about a short shifter, but these are supposed to make a big improvement to the whole shift action:
http://www.ft86club.com/forums/showthread.php?p=1334277 I have a set on order |
#3 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
Big Member
Drives: 2014 FR-S
Yea it's not too bad, but (maybe you have) comparing to other transmissions in other cars, it's not quite as good, and room for improvement. My 2006 STI was way better in this regard. It's weird how you can't really downshift into 2nd in a smooth motion, b/c you have to shift to the left pretty far in neutral position to then go down to 2nd.
Big Member
Drives: 2014 FR-S
I assume you don't actually double clutch, that was necessary on older cars when transmission wasn't synchronized or whatever. Now you only have to do single clutch.
#6 | |
Big Member
Drives: 2014 FR-S
Señor Member
What cars have you driven before? The 86 has the shortest throw g/box of any car I have driven. When you down shift to 2nd what is happening? Are you moving the stick to the wrong spot or are the synchros bulking and making it slower to shift into?
1974 TA22 Celica
2013 86 GT |
Big Member
Drives: 2014 FR-S
It's like I described. It seems like the move over to the left to get into 2nd from neutral is far, so that when going down from 3rd I gotta make it 2 conscious movements down to neutral and then into 2nd. It's like 2nd gear is too far to the left.
Señor Member
I would say that is just something you will get used to. But if it erks you a short shifter will fix that. Everyone has their own preferences with that sort of thing. Personally I would prefer a shorter clutch throw than the shorter shift.
1974 TA22 Celica
2013 86 GT |
#10 | |
Big Member
Drives: 2014 FR-S
FYI you can adjust the clutch pedal down. It's really easy once you get used to being upside down under the steering wheel. Just gotta make sure to test it out so that you didn't adjust too low. http://www.ft86club.com/forums/showt...dal+adjustment |
#11 |
Hella Flush
Drives: 2013 SWP BRZ
I noticed when I installed my weighted shift knob, shifting to the corner gears seemed to be a bit smoother.
#12 |
Off Topic
#13 |
Big Member
Drives: 2014 FR-S
#14 | |
Big Member
Drives: 2014 FR-S
| >>>Rev Works - Clutches - Drive Shafts - Short Shifters -All Your Drivetrain Needs<<< | Rev Works | Transmission and Driveline | 210 | 09-12-2014 03:45 PM |
| Short Shifters! Pro Billet vs. Kartboy | xDanger_208x | Engine, Exhaust, Transmission | 9 | 03-06-2014 09:32 AM |
| 1 Way To Really Improve Your Driving | CSG Mike | Tracking / Autocross / HPDE / Drifting | 5 | 01-22-2014 10:43 PM |
| ◘◘◘ Billet Pro Shop Short Shifters ◘◘◘ with colored lock outs - In Stock! | FT-86 SpeedFactory | Transmission and Driveline | 18 | 11-18-2013 10:44 PM |
| Looking for feedback and thoughts on Kartboy and TWM short shifters for our cars | OICU812 | Engine, Exhaust, Transmission | 2 | 07-25-2013 05:02 PM |
