Drives: 2013 Subaru BRZ limited
Anyone know what relay to use for horns?
I put in hella aftermarket horns and for some reason they aren't working now. I checked the fuses but those are fine. All the wiring is fine so I believe it's the relay. Thing is I'm bad with electric related things so I have no idea what relay I would need to get. If anyone could help me out with a Amazon link or anything it would be really appreciated. It's really nerve racking driving with no horns in a small car lol.
Sent from my SCH-I535 using Tapatalk |
Did you check the horn relay ...... (see "horn" upper left - follow the line).
humfrz |
Yea I was able to locate which one was the horn relay but I have no idea how to tell if it's good or not. I'm assuming it isn't since both fuses are intact.
#4 | |
OR [ame="https://www.youtube.com/watch?v=3JB63ebFfgU"]Auto Repair & Mechanics : How to Test a Car Relay - YouTube[/ame] beep-beep ..... humfrz |
Which relay do you think would be the best to swap it out with? I don't want to mess with anything that shouldn't be messed with.
DADA
Drives: 2013
You dont need a relay, with stock fuse it works fine.
Double check your wiring |
They've been on the car for a good three months without a problem, there's a stuck relay though. If the stock relay goes bad would that cause them to stop working?
Drives: SC RB FRS
you can swap relay with anyone that looks the same, heater, fan, drl.
you can also have your friend honk the horn and you feel for the relay clicking. |
#9 | |
humfrz |
| DIY - Hella Supertone horns installation on FR-S | driver01 | DIY (Do-It-Yourself) Guides | 93 | 07-22-2019 04:08 PM |
| DIY - Hella Horns | olorin | DIY (Do-It-Yourself) Guides | 21 | 06-01-2017 04:59 AM |
| HID Relay | FRSure | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 03-13-2014 09:50 PM |
| IG2 Relay issue | B_Rad | Issues | Warranty | Recalls / TSB | 11 | 09-11-2013 07:26 AM |
| WTB: OEM Flasher Relay | CanibeatNoel | Audio/Visual, Electronics, Infotainment, NAV | 2 | 05-01-2013 02:58 PM |
