Old 03-30-2014, 10:50 AM   #1
BRZlimited
BRZlimited's Avatar
Drives: 2013 Subaru BRZ limited
Anyone know what relay to use for horns?
I put in hella aftermarket horns and for some reason they aren't working now. I checked the fuses but those are fine. All the wiring is fine so I believe it's the relay. Thing is I'm bad with electric related things so I have no idea what relay I would need to get. If anyone could help me out with a Amazon link or anything it would be really appreciated. It's really nerve racking driving with no horns in a small car lol.
BRZlimited is offline   Reply With Quote
Old 03-30-2014, 01:22 PM   #2
Did you check the horn relay ...... (see "horn" upper left - follow the line).
Old 03-30-2014, 05:02 PM   #3
BRZlimited
BRZlimited's Avatar
Yea I was able to locate which one was the horn relay but I have no idea how to tell if it's good or not. I'm assuming it isn't since both fuses are intact.
Old 03-30-2014, 06:29 PM   #4
Well, now, the easiest way is to swap it with another relay and see if the horn works.
OR
[ame="https://www.youtube.com/watch?v=3JB63ebFfgU"]Auto Repair & Mechanics : How to Test a Car Relay - YouTube[/ame]
beep-beep ..... humfrz
Old 03-30-2014, 08:02 PM   #5
BRZlimited
BRZlimited's Avatar
Which relay do you think would be the best to swap it out with? I don't want to mess with anything that shouldn't be messed with.
Old 03-30-2014, 09:58 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
You dont need a relay, with stock fuse it works fine.
Double check your wiring
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
jonzhuxD (03-30-2014)
Old 03-30-2014, 11:14 PM   #7
BRZlimited
BRZlimited's Avatar
They've been on the car for a good three months without a problem, there's a stuck relay though. If the stock relay goes bad would that cause them to stop working?
Old 03-31-2014, 01:54 AM   #8
pitstops
Drives: SC RB FRS
you can swap relay with anyone that looks the same, heater, fan, drl.
you can also have your friend honk the horn and you feel for the relay clicking.
pitstops is offline   Reply With Quote
Old 03-31-2014, 02:27 AM   #9
There ya go @BRZlimited ...... ol pitstops comes through ....
DIY - Hella Supertone horns installation on FR-S driver01 DIY (Do-It-Yourself) Guides 93 07-22-2019 04:08 PM
DIY - Hella Horns olorin DIY (Do-It-Yourself) Guides 21 06-01-2017 04:59 AM
HID Relay FRSure Cosmetic Modification (Interior/Exterior/Lighting) 14 03-13-2014 09:50 PM
IG2 Relay issue B_Rad Issues | Warranty | Recalls / TSB 11 09-11-2013 07:26 AM
WTB: OEM Flasher Relay CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 2 05-01-2013 02:58 PM
