Old 03-28-2014, 11:27 PM   #1
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool Beat-Sonic Front and Rear Camera
Anyone planning on adding this to their Monogram
I plan to add both front and back, but I am wondering the best way place to put these, especially on the front as I am not running a plate.
Check out the vid:
[ame="http://www.youtube.com/watch?v=PncT0EJQFWc"]Beat-Sonic front and rear camera on BeSpoke - YouTube[/ame]
Chad86 is offline   Reply With Quote
Old 03-29-2014, 01:01 AM   #2
humfrz
I'd just mount it in the grill and paint it black.....
humfrz
Old 03-29-2014, 03:52 AM   #3
Drive
Crickets...
Drive's Avatar
Drives: FR-S 10 Series
Not needed. Real men don't need backup or front cameras
Smile on every turn.
Drive is offline   Reply With Quote
Old 03-29-2014, 03:57 AM   #4
Dark
Elite Padawan
Dark's Avatar
Real men make mistakes.
Dark
Dark is offline   Reply With Quote
The Following User Says Thank You to Dark For This Useful Post:
Missy (03-29-2014)
Old 03-29-2014, 04:17 AM   #5
Missy
Blue Nose
Missy's Avatar
Drives: 2013 FR-S 10 series
Yes...yes they do.
However, these are the nicest I've seen yet. Not to terribly noticeable.
Missy is offline   Reply With Quote
Old 03-29-2014, 11:52 AM   #6
Stevie86
Stevie86's Avatar
Drives: '13 FRS AT "slush"
I would put the camera above the license plate and underneath the license plate lights to keep them hidden, I think it'll look cleaner.
Stevie86 is offline   Reply With Quote
Old 03-29-2014, 12:09 PM   #7
PSORngr
I have the backup camera. I really like it. It was a real pain in the ass routing the wiring though (first time I'd ever done anything like that with a car). I still need to figure out how to get the wire through the rubber hose thing at the trunk. I currently just have it hanging free in the trunk to the lid.
PSORngr is offline   Reply With Quote
The Following User Says Thank You to PSORngr For This Useful Post:
Chad86 (03-29-2014)
Old 06-01-2014, 04:16 AM   #8
notout86
Drives: GTS 86 auto
I have just done the rubber hose thing. Firstly I was farnarcling with pushing something stiff but flexible through, then taping the wiring to it and pulling it back through. This is a standard method. Then I realised we have a tube that can be made short by concertinering BINGO!!
Disconnect both ends of the tube. Decide which way you want to thread through. (in my case it was better to go in from the body end as that connector was more slender).
Spray silicone spray in the tube to make it slippery. Spray the connector you want to put through too.... BUT DO NOT GET SPRAY ON THE CONTACTS..Toyota specifically warn that silica is left behind and messes conductivity.
Push the connector in, then further with something blunt like the blunt end of a pencil. Keeping the connector pushed in, concertina the tube towards the end you pushed in from ant while keeping it compressed, squash the tube and grip the connector within. Keeping it gripped, let the concertina extend back along the wiring. Get the idea? .. keep doing that until you have reached the other end.
All that silicone spray will make refitting the grommets a sensual experience afterwards.
BTW I am routing the lead out of the light cluster under the edge of one of the lights. They have a foam dust excluder gasket which will deform just enough.
I was not happy with the view from the standard mounting position so am mounting the camera almost centrally. If you are using parking guidelines in your view and compare the geometry you will see what I mean.
p.s. do you know Sandra Bullock?
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Fs: Beat-Sonic BCAM7 Rear Backup Camera (New) ucsmfu Canada Classifieds 2 01-29-2014 08:00 PM
Beat-Sonic Backup Camera and Harness smellslikecurry Audio/Visual, Electronics, Infotainment, NAV 3 01-25-2014 03:08 PM
Fs: Beat-Sonic BCAM7 Rear Backup Camera ucsmfu Audio/Visual, Electronics, Infotainment, NAV 0 01-09-2014 11:45 AM
Fs: Beat-Sonic BCAM7 Rear Backup Camera ucsmfu Canada Classifieds 0 01-05-2014 07:20 AM
beat-sonic harness & rydeen camera help lbroskee Electronics | Audio | NAV | Infotainment 7 07-17-2013 12:48 AM
