Old 07-15-2013, 05:17 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
beat-sonic harness & rydeen camera help
so i have the combo listed above and it should work but i was having some issues. all cables up front are pretty much simple (i assume the red wire from the RCA plug goes into the BS white one). the question is im not sure where to hook up the red wire by the ground on the camera. i tried touching it to the green power wire on my amp as i heard that was power, but i get nothing from my Bespoke when i shift to reverse. has any1 had this setup combo and successful install? can't find anything
lbroskee is offline   Reply With Quote
Old 07-16-2013, 02:11 AM   #2
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Did you buy this harness from Beatsonic? if so, you can following the instruction on the PDF file in the below link;
http://www.beatsonicusa.com/stereo/c...xus/bcus2.html
#944_10_Series_FRS is offline   Reply With Quote
Old 07-16-2013, 09:55 AM   #3
lbroskee
lbroskee's Avatar
this is the 1 part im unsure of tho
Step 7: Route the backup camera wiring
- The camera power will need to be routed to the rear of the head unit. In order to do this, the line will
need to be extended approximately 4.5ft if routing through the passenger's side. If routing the wires
through the driver's side, should not need that much extra wires. (This may vary depending on what
camera is being used)
where on the back of the headunit do i route the power?
Old 07-16-2013, 10:42 AM   #4
#944_10_Series_FRS
I used the harness from David at Svxdc and it is very straight forward. Out of the 16 pin, there is a 6v power lead which power your camera when the HU boot up as well as when it back up. Also, you will have to run an back up trigger into pin #2 of your 28 pin harness.
Old 07-16-2013, 06:35 PM   #5
lbroskee
lbroskee's Avatar
I got the trigger on the 28 pin. As for the one on the 16 pin, which 1?
Old 07-16-2013, 08:00 PM   #6
#944_10_Series_FRS
On the 16 pin, the 6v power lead you need to hook it to the power of the camera.
On the 28 pin harness, pin #2 which is the reverse trigger, you need to route it to the side panel and hook it up to the power wire (only on where the car shift into reverse). This will trigger the HU to turn on camera function when your car in reverse so you can see the image.
Good luck!
Old 07-16-2013, 08:10 PM   #7
lbroskee
lbroskee's Avatar
Good luck!
Hopefully it clears up this weekend so i can get this done. The side panel wire... Is it the light pink or dark pink wire? Text guides say slot 5(dark) yet pics show it on light pink
Old 07-16-2013, 11:48 PM   #8
#944_10_Series_FRS
I just hook this up yesterday. I forgot the color, there are 2 column of wire, the one is on the left hand side when you look at the wire.
Beat-Sonic Backup Camera & Adapter for FR-S & BRZ Group Buy Beat-Sonic Audio/Visual, Electronics, Infotainment, NAV 350 09-14-2015 08:11 PM
Pioneer HU and Rydeen Duo Camera pauland Electronics | Audio | NAV | Infotainment 5 03-04-2014 05:20 PM
Beat-Sonic FR-S Photos Beat-Sonic FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 46 08-29-2013 10:35 AM
Beat-Sonic Backup Camera & Adapter for FR-S (Bespoke) & BRZ Special Price Beat-Sonic Audio/Visual, Electronics, Infotainment, NAV 60 07-15-2013 03:58 PM
