Old 08-15-2013, 03:54 AM   #1
SliverBrz
Drives: Silver 2013 BRZ limited
Alignment question after swift sprigns
So I had an alignment done when i got my swift springs install. They printed out a sheet and I never bothered to look at it.
Anyways, what made me look at the sheet again that sat in my glove box was the fact that i noticed on my rear, one wheel seemed more camber than the other. It was slight but I personally noticed it.
Im pretty much a noob still on alignment and i read the sheet.
it says left rear -2.14 degrees and right rear -2.29 degrees.
IS there a reason they did it that way?
SliverBrz is offline   Reply With Quote
Old 08-15-2013, 04:06 AM   #2
cnk
Drives: '13 DGM BRZ Limited
There is no camber adjustment in the rear unless you get LCA's or UCA bushings. Some have used a modified camber bolt on the subframe to LCA mount as well.
cnk is offline   Reply With Quote
Old 08-15-2013, 04:31 AM   #3
SliverBrz
oh ok im a noob still thanks lol
Old 08-15-2013, 10:42 AM   #4
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
i also had unequal rear camber after spring installation; i had LCAs installed to equal them out. from talking to folks who have had springs installed, it's more common than not, to end up with unequal rear camber. the difference from one side to another varies; mine was about .25° different from one side to the other.
shiumai is offline   Reply With Quote
Old 08-15-2013, 10:56 AM   #5
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
That's not a huge difference in camber anyway. I wouldn't be overly worried about it.
FReSh is offline   Reply With Quote
Old 08-15-2013, 01:32 PM   #6
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
Honestly, I think you're running too much camber in the rear. I could be wrong, but my handling improved a great deal once I got my rear camber around -1.5. It also helped to have it equaled out and running a bit of toe in. I think getting some camber adjustment bushings or a rear LCA would really help out the consistency of your handling, although that's just my experience with the platform.
console_cowboy is offline   Reply With Quote
Old 08-15-2013, 03:59 PM   #7
SliverBrz
So if i get LCA's in the rear I can adjust camber? Which ones are good?
Also what about the front, I want to camber it a little, what should i go with up there?
Old 08-15-2013, 04:09 PM   #8
cnk
For LCA's, I went with the SPC arms as they are ~$200 and get the job done. You can look at others like Cusco, RacerX, GTWorx, etc. as well.
For the front, just get the OEM crash bolts or some camber bolts.
Old 08-15-2013, 04:31 PM   #9
console_cowboy
I went with the OEM crash bolts and SPC rear LCAs as well. It was the most cost effective and easiest install option there is currently, but any of the rear LCAs will do the job.
Old 08-15-2013, 04:32 PM   #10
SliverBrz
thank you =)
Old 08-15-2013, 06:53 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
~-2.2 camber isn't a big deal, and will give greater ultimate grip vs. less camber. Honestly I wouldn't bother with getting components to "correct" it. What does the rest of your alignment look like?
Old 08-15-2013, 07:41 PM   #12
SliverBrz
Front Camber is -.14 , and -.16
Toe 0 Front
Toe 1/16" Rear
The Following User Says Thank You to SliverBrz For This Useful Post:
hanabie (08-15-2013)
Old 08-15-2013, 08:58 PM   #13
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Toe 0 Front
Toe 1/16" Rear
I have swift springs installed too.
Toe +0.16deg (close to 1/16")
Rear Chamber - 1.9 or -2.0 deg
hanabie is offline   Reply With Quote
Old 08-17-2013, 07:54 PM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
Toe 0 Front
Toe 1/16" Rear
IMO, you need more front camber, not less rear! -.14/-.16 is abysmally low. Crash bolts would get you at least a bit more for reasonable $$$.
Toe looks reasonable.
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 01:52 PM
(GOOD QUESTION) Which Spring make a higher front bumper? Tein H tech, RS-R or Swift? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-14-2013 10:52 PM
Alignment question retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-11-2013 11:44 PM
toe, camber, castor? basic alignment question? rainmonkey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 05-18-2013 02:38 AM
RCE vs Swift: Any Insight? boredom.is.me Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 03-24-2013 09:45 PM
