Old 03-27-2014, 12:29 AM   #1
csworldfan
Lower the seats?
Hey everyone. First of all, just picked a 2013 ignition silver 6mt. Absolutely love the car, i just have one issue. I'm 6'7, and my right knee sits very close to the steering wheel. That's with the seat all the way back and down. Is there any aftermarket brackets that lower the seat? I saw that DA motorsports was making one, but that fell through. Maybe there's another possible solution? I appreciate the input guys.
Happy motoring.
csworldfan is offline   Reply With Quote
The Following User Says Thank You to csworldfan For This Useful Post:
forzajuve (03-28-2014)
Old 03-27-2014, 12:32 AM   #2
wootwoot
Drives: FRS
Nothing is out yet... There was a vendor that was working on it for a while but I don't think it ever came to market.
wootwoot is offline   Reply With Quote
Old 03-27-2014, 01:41 AM   #3
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
The FR-S can accommodate tall and semi-large people. I'm 6'1" 205lbs and its a great fit for me. Others have said the same. If I recall correctly we have a 6'4" dude on this forum who thinks the cockpit comfortable and thrilling at the same time.
But, 6'7" is a different and higher tier of of BIGNESS.
The way I understood the OEM seating position is that at the lowest setting your dairy aire is 10 inches from the pavement.
I'm sure custom seats are an option. I'm curious to learn what you modify. Update the thread when you make you modification.
Jertronic.
Jertronic is offline   Reply With Quote
Old 03-27-2014, 01:50 AM   #4
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Time for aftermarket seats and low rails, maybe?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 03-27-2014, 09:55 AM   #5
csworldfan
Thanks for the input guys, I appreciate it. I would definitely go the aftermarket seat route, if it wasn't for my 5'2 wife who drives the car... She wouldn't be able to see over the dash. Is it possible to remove the knee bad? It's not head room I need, it's just an extra inch or so of knee room.
Old 03-27-2014, 09:57 AM   #6
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I am 6'2" and I need more headroom with a helmet, hopefully there's some lowered rails that come out in the future.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 03-27-2014, 10:02 AM   #7
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
there was a vendor working on it, but they stopped posting in the thread. everyone assumed they flaked.
im 6'4"/6'5" and NEED helmet room. I have to do the gangsta lean to make it happen.
BTW, you can strech the seat cushion spring and gain an extra half inch or so of headroom.
supramkivtt2jz is offline   Reply With Quote
Old 03-27-2014, 10:20 AM   #8
Model Citizen
Lacking brains
Drives: frz
I'm about 6'3" with a long torso, I fit terribly in small cars. I made the leap into this one because the headroom was just bearable in stock form and at the time it looked like the damotorsports solution was on the horizon. They went radio silent on the product and I started on trying to find my own solution.
Springs stretched and the plastic ties that bind them cut did help, not enough to clear a helmet however.
This is what I ended up doing, and it has been fantastic. Gf needs a booster seat to drive the car comfortably now (she's averageish height 5'7" or so). Shorter people that sit in the car can barely see over the wheel. The seat pan is basically sitting on the floor and thanks to the scooped design of the base just about all the headroom that can be gained is.
http://www.ft86club.com/forums/showthread.php?t=46801
Is your issue slouching for headroom that's causing knees into the wheel?
Model Citizen is offline   Reply With Quote
Old 03-27-2014, 10:26 AM   #9
gily25
Drives: Silica BRZ 6MT
Do you need the rear seat? Maybe you could do a rear seat delete and a longer seat bracket to slide back another 1/2-1" http://ft86speedfactory.com/seibon-c...panel-493.html You may not even need to change the seat slide, I don't know if that is the end of the slide or the seat cushion stops it first.
You might check out some of the forums for other small cars and see if there are any hints or tips. Miata, del sol, s2000...
gily25 is offline   Reply With Quote
Old 03-27-2014, 10:30 AM   #10
csworldfan
Well alot of my height is in my legs, so when sitting up straight my head barely touches the roof, and my knee comes very close to the steering wheel. I do lean the seat back pretty far though. I'm almost thinking about just getting an aftermarket steering wheel and an extension to bring it closer to me and away from my knee. I might look into the rx8 seats though, how much did you pay for them?
Old 03-27-2014, 10:33 AM   #11
humfrz
Some of the "longer" Miata owners used to place spacers (and longer bolts) under the rear of the seat track to tilt the seat to allow more leg room. Don't know if that would work (or is possible) in a FR-S.....??
humfrz
Old 03-27-2014, 10:36 AM   #12
Model Citizen
Lacking brains
Drives: frz
I got lucky. $75 for the cushions, <$140 ish for standard seat and frame. Going rate on the rx8 recaros are $600+ ish, once you find them. The standard rx8 seat base basically has a flat cushion, the Recaro was scooped out, not sure about the leather variants
Legroom isn't normally much of an issue for me (other than in a solstice). Headroom is always the killer, but who knows maybe the altering of angles would help you out enough.
Tilt wheel in this car isn't enough?
Old 03-27-2014, 11:49 AM   #13
csworldfan
Later this evening I'll take a picture so everyone had a better understanding.
Old 03-27-2014, 11:33 PM   #14
csworldfan
So this is my issue... My knee is just too Damn close to the steering wheel. This is with the seat all the way back, and lowered. Any suggestions?
Lumbar support for seats? My lower back is killing me Indestruct Cosmetic Modification (Interior/Exterior/Lighting) 65 05-18-2017 11:56 AM
Scion FRS Stock Full Seats (Driver / Passenger / Rear seats) for sale Sehwan Kim Interior Parts (Incl. Lighting) 1 01-28-2015 07:35 AM
lower stock seats? choi0706 Cosmetic Modification (Interior/Exterior/Lighting) 5 07-26-2013 06:52 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 06:45 PM
Lower the seats? MrMista Scion FR-S / Toyota 86 GT86 General Forum 11 04-19-2013 07:41 PM
