Old 03-24-2014, 12:52 PM   #1
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Liquid leaking
I went for a 40 minute drive and had the AC on for maybe 20 seconds.
But I noticed this leak underneath my car under the passenger footwell. It doesn't seem to be oil, but I do know these cars have the "missing" engine coolant. Could this be it?
Anything else?
subiestyle is offline   Reply With Quote
Old 03-24-2014, 01:43 PM   #2
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
If it's just water, it could be AC condensation.
If it's coolant, it should be colored and have some smell to it.
From searching: http://www.ft86club.com/forums/showt...php?p=1482517; pics look similar.
retrofit
BaeK is offline   Reply With Quote
Old 03-24-2014, 01:59 PM   #3
subiestyle
subiestyle's Avatar
I'm hoping somebody can confirm it is ac condensation from the pics.
Old 03-24-2014, 02:06 PM   #4
DJCarbine
Thupercharged
DJCarbine's Avatar
Stick your finger in it, it should be painfully obvious if its oil/coolant/water
Also, were you driving with defrost on? By default defrost turns the AC on to remove moisture from the air to aid in unfogging the windshield
2013 FRS
Vortech V3 11psi
Old 03-24-2014, 02:15 PM   #5
Dezoris
Dezoris's Avatar
Drainage tube is connected to trans/exhaust tunnel on passenger side of frame, right about at that location. Feel up there should be able to grab the rubber utter.
Old 03-24-2014, 02:17 PM   #6
subiestyle
subiestyle's Avatar
No front or rear defrost. But I did have the front air option to defrost/footwell. Unless its different with this car, that shouldn't turn on AC.
I didn't taste it, but there was no smell. I'm fairly sure it was water, but I want to double check.
Old 03-24-2014, 02:53 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
I believe the blend setting defrost/footwell also uses the AC, I usually use this setting in winter to keep the windshield clear
2013 FRS
Vortech V3 11psi
Old 03-24-2014, 02:58 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It seems to be about right as the location of the AC drain. I think thats it.
Old 03-24-2014, 03:29 PM   #9
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah, that setting does turn the A/C on. It's just water from condensation as others have said. That is perfectly normal.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 03-25-2014, 12:30 AM   #10
humfrz
Most likely it's water. Heck, have a taste .... that will tell you. No, no matter if it's stale water, coolant, gas or oil .... a taste ain't gonna hurt ya ....
humfrz
Old 03-25-2014, 12:34 AM   #11
husker741
That's what I like to tell girls but for some reason it never works in my favor.
husker741 is offline   Reply With Quote
Old 03-25-2014, 01:35 AM   #12
humfrz
Well, I don't know what ta tell ya now days ....... back in the day, we would mix ground up lemon peel with shaved ice and pack it into a tall glass and fill it with vodka and give it the girls telling them it was lemonade.
Worked good, but you had to move fast, to catch them just after they fell off the hay bale and before they threw up .....
@subiestyle ..... I'm pretty sure what's dripping out of your car ain't vodka ....
humfrz
Old 03-25-2014, 01:38 AM   #13
husker741
humfrz
I'm not sure you're picking up what I'm putting down...
Old 03-25-2014, 01:43 AM   #14
humfrz
Ohhhhh........well, in that case, I suggest you ......
..... bad boy!
husker741 (03-25-2014)
Weird sounds and liquid dripping from car kam Issues | Warranty | Recalls / TSB 21 05-07-2014 07:01 PM
FA20CLUB Oil Cooler Kit Liquid/Liquid Andy@FA20Club Engine, Exhaust, Transmission 46 02-03-2014 11:10 AM
Dark Liquid (oil?) on muffler tip calmtigers Scion FR-S / Toyota 86 GT86 General Forum 12 01-01-2014 08:30 PM
Bubbling/knocking (but not liquid) sound aside from chirping mike_ekim1024 Issues | Warranty | Recalls / TSB 22 05-05-2013 03:20 PM
Anyone an Idea what that liquid is? Killerbee Scion FR-S / Toyota 86 GT86 General Forum 13 12-10-2012 10:33 PM
