Old 03-20-2014, 08:37 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Power by Max LCAs with ProKit springs
I'm looking at doing this combo along with the factory bolts to adjust front camber.
These lcas do lower the car an extra 25-40 mm depending on your choosing. Will this make the rear sit lower and look mismatched to the front? Are these necessary for prokit?
http://www.partsshopmax.com/page.php?14
Old 03-20-2014, 08:54 PM   #2
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Those are intended for coilovers, so you can get really low without losing as much travel. Alternately, you can raise the coilovers to keep a more moderate height and have even more travel.
With springs, it will just make the rear 25 or 40mm lower, with no way to match that in front.
I do highly recommend their products. Cool guys at the shop, and they don't make junk parts. I'm only running their spacers right now, but I will pick up the LCAs if I ever go coilovers. I've ridden in the shop FR-S and it is not harsh like I would have thought for a car that's nearly scraping the ground. It WAS noisy, though, with all kinds of solid bushings.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 03-20-2014, 10:21 PM   #3
B-R-Z
B-R-Z's Avatar
What solution is there to fix minor rear camber issues?
Old 03-21-2014, 09:44 AM   #4
2point0
2point0's Avatar
A different set of LCAs that use stock mounting points for the shock. I believe the Whiteline set is a reasonable price.
CRAZY LOW PRICES ON EIBACH SPRINGS (PROKIT AND SPORTLINE) genometuning Brakes, Suspension, Chassis 248 01-17-2015 09:53 PM
FS: SPC Rear LCAs, SPC Camber Bolts, Eibach Sportline Springs & Sway Bars, Bilsteins BRZZZZZZZZZZ Canada Classifieds 7 03-20-2014 12:16 AM
Difference in Eibach prokit springs?? leej Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-18-2012 08:54 PM
Eibach prokit springs group buy? leej Australia Classifieds 27 06-27-2012 09:47 AM
