Old 03-20-2014, 05:06 PM   #1
jdair28
install TRD radiator cap & Oil Filler Cap Billet Aluminum
hey all,
I ordered these TRD parts, but I have no idea how to replace the stock ones. For the radiator cap, I've twisted it but cant seem to pry it off and the oil filler cap just won't budge. I guess I'm afraid of breaking these so I really haven't put much force. These probably makes me look really stupid but if anyone can give more insight here, I would appreciate it. Sorry in advance for such a newb request.
thanks for your time
jdair28 is offline   Reply With Quote
Old 03-20-2014, 05:13 PM   #2
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Pic of under the radiator cap please.
I had the same problem.
For the oil filter cap you might need a tool.
Carlitoz3 is offline   Reply With Quote
Old 03-20-2014, 09:57 PM   #3
Ocho Seis
Ocho Seis's Avatar
Drives: 2013 Frs
Rad cap push down turn left , pull off , make sure you do this when the car is cold not hot if not u can burn ur self since the coolent is under pressure when hot..
Ocho Seis is offline   Reply With Quote
The Following User Says Thank You to Ocho Seis For This Useful Post:
hotpanda1 (03-20-2014)
Old 03-20-2014, 10:39 PM   #4
OURO3OROS
Drives: 2013 Asphalt FR-S
This works for over-the-counter meds too
OURO3OROS is offline   Reply With Quote
Old 03-25-2014, 02:47 PM   #5
jdair28
so i was able to replace the radiator cap, you just have to really pry it off (and i think pressing down on it so thanks for that tip). Still have no idea how to replace the "stock oil filler cap." It's the yellow piece thats directly to the right of the black oil filter i believe? anyone know how to switch it out?
Old 03-25-2014, 04:59 PM   #6
mabviper
Drives: WRB BRZ
There's nothing to replacing that oil filler cap. Just turn it counter clockwise. The first time I changed my oil, it was also a bit stiff.
mabviper is offline   Reply With Quote
Old 03-25-2014, 06:18 PM   #7
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Also make sure you retain and reuse the oil cap o-ring for proper alignment. You just have to muscle it off :-)
Jman1759 is offline   Reply With Quote
FBM Aluminum Radiator Shroud Release FullBlown Engine, Exhaust, Transmission 7 09-28-2014 05:01 PM
FBM Aluminum Radiator $279 shipped FullBlown Engine, Exhaust, Bolt-Ons 0 01-06-2014 05:40 PM
Aluminum radiator install and impressions Tye300 Engine, Exhaust, Transmission 15 10-28-2013 01:52 PM
SRP Billet Aluminum Door Sills pedalpusher Interior Parts (Incl. Lighting) 2 09-20-2012 10:25 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
