Drives: Scion FRS
FBM Aluminum Radiator Shroud Release
We are finally ready to release our Radiator Fan shrouds with Dual 12" Spal Fans.
Our aluminum shroud helps pull the heat away from the radiator's complete surface versus just where the fans would usually mount. By doing so, it helps cool the radiator more efficiently. Our shrouds are designed to fit our FBM Radiators, Koyo or OEM . Please specify which radiator you have at the time of ordering since the mounting points are different. Retail $349 (with fans) Introductory Price $299 (with fans) FBM Radiator Alone $279 FBM Radiator + Shroud Combo $549 Radiator Hoses $69 ![]() ![]() ![]() We Have plenty of Shrouds Being built and will be instock ready to ship.
Drives: Scion FR-S
Does this fit an AT? If so I'm in!
I believe it does
Drives: Scion FR-S
Realized I should clarify that i meant the radiator?
Doesn't the auto have an external cooler?
Drives: Scion FR-S
It does. I just didn't know if the radiator has a cooler as well. My car is in the body shop still for the 5th time from being hit...so I couldn't go out and look
Found mention in a different posting that the MT and AT use the same radiator. Thanks Dipstik! |
is there option for bigger fans?
Edit, what I mean, higher flowing fan option
I'd think if you could fit a deeper fan you could as long as they're the same diameter. I think LJ picked the highest cfm fans that he could fit with his kits, others may vary.
| Spal Fan Shroud & Koyo Radiator | Carolina Dyno | Forced Induction | 64 | 12-14-2016 08:38 PM |
| FBM Aluminum Radiator Shroud Release | FullBlown | Forced Induction | 105 | 09-28-2014 03:22 PM |
| FBM Aluminum Radiator Shroud Release | FullBlown | Engine, Exhaust, Bolt-Ons | 0 | 01-22-2014 06:29 PM |
| FBM Aluminum Radiator $279 shipped | FullBlown | Engine, Exhaust, Bolt-Ons | 0 | 01-06-2014 05:40 PM |
| Product Release! Mishimoto Peformance Aluminum Radiator for Scion FR-S / Subaru BRZ! | Mishimoto | Announcements, Contests, Giveaways | 1 | 10-01-2013 11:44 AM |
