Old 03-19-2014, 04:59 PM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Good front/rear camber value for my setup?
Stock suspension
225/45 RE11A's on a 17x8 RPF1 +45 offset
I'll be tracking the car in the WinMax 86 CUP (mostly Willow courses)
I'm looking to get the SPC LCA and either camber bolts or plates, depending on the answers in this thread.
What would you suggest are good (negative) camber values for F/R?
Will the camber bolts be enough to achieve that value in the front?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 03-19-2014, 08:01 PM   #2
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
-3 front,-2 rear is good starting point
Bill
Scooby South is offline   Reply With Quote
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
EN2_Squirrel (03-20-2014), retrosmiths (03-19-2014)
Old 03-19-2014, 08:12 PM   #3
was385
Drives: MT WRB BRZ Limited, 2007 911s
And just as reference, I believe you can only get a little less than 1.5 degrees with camber bolts. Though if you want more you may want to throw on a good set of lowering springs with the bolts to pick up more camber and get a little bump in performance, which would still be significantly less than camber plates.
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
Old 03-19-2014, 08:16 PM   #4
juliog
juliog's Avatar
Drives: 86
If it helps, I have -1.1 F / -2.0 R with OEM suspension, Whiteline camber bolts and Cusco rear LCAs. You can only get so much camber with the bolts. Still leaps and bounds over OEM alignment (or lack thereof).
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
Old 03-19-2014, 11:14 PM   #5
retrosmiths
Can't replace the stock springs though, I've maxed out my points for my class. However, camber kits are free. You know if it's worth it to get plates instead of bolts, for the $$$ difference?
2013 Scion FR-S
Old 03-20-2014, 12:49 AM   #6
juliog
juliog's Avatar
Drives: 86
IMHO they'd be worth it if you think you can use that extra negative front camber to go faster, and you don't plan on upgrading to coil-overs (or just springs) anytime soon.
Old 03-20-2014, 10:00 AM   #7
was385
Got it. I'm not the right person to answer that question because it's beyond my knowledge level, though I'm sure some of the more experienced guys on here will have an answer for you.
Old 03-20-2014, 11:11 AM   #8
Max out the camber you can get, but you need to do both the front AND the rear, with the front being more important.
retrosmiths (03-20-2014)
Old 03-20-2014, 06:54 PM   #9
retrosmiths
Is that the max you can get with the bolts?
2013 Scion FR-S
Old 03-20-2014, 06:57 PM   #10
juliog
juliog's Avatar
Drives: 86
Yeah, that's the maximum the shop was able to dial in, but YMMV...
Old 03-20-2014, 07:00 PM   #11
was385
Hopefully at some point some company makes something similar to the Com-C mounts... except you know that work
Old 03-20-2014, 07:15 PM   #12
EN2_Squirrel
EN2_Squirrel's Avatar
I have SPC LCA's (old version) they are broken and had to be welded in place. I am upgrading to whiteline.
EN2_Squirrel is offline   Reply With Quote
Old 03-20-2014, 09:50 PM   #13
We recommend SPL.
EN2_Squirrel (03-21-2014)
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Good static front/rear camber for street and track? dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 03-28-2014 10:48 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
