Old 03-15-2014, 05:44 PM   #1
lorip713
Stuck in manual drive?
I always drive in "drive." I do not use the manual setting. I recently had a 1400 road trip and the day after I returned and the odometer hit 10,000, the care felt funny while driving, like the engine was revving and I could really feel the car shifting as my speed increased. The speedometer also took a long time to come down when I slowed and at one point said 5 mph when I was completely stopped. I have never driven the car in "manual" (sorry guys, chick here, it's probably wasted on me) but I know for a fact that when I first bought the car 8 months ago you could hit the paddles with the car in drive and nothing happened. Now, when you hit the paddles in drive, the manual gears show up on the dash. The service guy at the dealer thinks I'm wrong about everything. I know something's not right. Suggestions? Thanks in advance.
lorip713 is offline   Reply With Quote
Old 03-15-2014, 05:46 PM   #2
Scionshaun
Aloha!
Drives: Whiteout
You can use the paddles in drive mode and it shifts but after a few seconds it goes back to drive. That's odd about being completely at a complete stop with speedometer at 5. Is go take it in and check it out, again.
Scionshaun is offline   Reply With Quote
Old 03-15-2014, 05:48 PM   #3
jskurucz
Yep!
jskurucz's Avatar
Drives: 2015 WRX Sti
If you hit the paddles while in "drive" the car will automatically go to manual mode, unless you hit the up shift paddle while in 6th then it won't do anything. Same goes for down and gear 1.
However, I am not sure if the engine will shift automatically once the RPMs go slow high like in manual mode. I never tried it.
jskurucz is offline   Reply With Quote
Old 03-15-2014, 06:58 PM   #4
Tromatic
It will shift up or down, but unless you have the stick in the manual mode it will go back to "D" on it's own.
OP, when you are using the paddles, do you have it in "Manual" mode? Regardless, if you are still showing something on the speedo when stopped that would be a problem.
Tromatic is offline   Reply With Quote
Old 03-15-2014, 09:41 PM   #5
lorip713
No, I'm in drive. I do not use manual but it feels like the car is in it anyway. Not really sure how to explain it but it just feels different.
Old 03-15-2014, 10:14 PM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Are you sure the car isn't in sport mode?
Are you sure the car is completely stopped at 5mph? I know sometimes you stop at a stop sign, look down and it says 4/5 and you feel like you're stopped but you really aren't.
Old 03-15-2014, 10:16 PM   #7
Ocala FR-S
Ocala FR-S's Avatar
Drives: 2013 FR-S AT Argento
These are my best theories for what you are experiencing.
Unless your car was defective from day one, the paddles do work in regular drive D. If you were easy on the gas and tried to shift to a higher gear too early, it won't let you. That may have made it seem like they weren't active. If lately you tried it while under a little heavier acceleration or for a downshift, you may have been surprised that in fact they do work in D.
Take this in the best spirit that it is intended. The big dial in the middle of your dash is a tachometer. It measures the speed that your engine is turning and not the wheels on your car. With an automatic the engine is still spinning slowly even when the wheels on the road are at a dead stop. The tachometer will sit between 0 and 1 or five hash marks above 0. Could that be what you are looking at? The speedometer is the dial to the left and should read 0 when you are stopped as well as the digital readout with the big orange numbers. Forgive me if you already knew any of this.
Ocala FR-S is offline   Reply With Quote
Old 03-15-2014, 11:34 PM   #8
lorip713
[QUOTE=dem00n;1602644]Are you sure the car isn't in sport mode?
Are you sure the car is completely stopped at 5mph? I know sometimes you stop at a stop sign, look down and it says 4/5 and you feel like you're stopped but you really aren't.[/QUO
Yeah, I'm sure. Stopped in my driveway with my foot on the brake.
Old 03-15-2014, 11:42 PM   #9
lorip713
Take this in the best spirit that it is intended. The big dial in the middle of your dash is a tachometer. It measures the speed that your engine is turning and not the wheels on your car. With an automatic the engine is still spinning slowly even when the wheels on the road are at a dead stop. The tachometer will sit between 0 and 1 or five hash marks above 0. Could that be what you are looking at? The speedometer is the dial to the left and should read 0 when you are stopped as well as the digital readout with the big orange numbers. Forgive me if you already knew any of this.[/QUOTE]
Seriously? I was stopped in my driveway with my foot on the brake. I do know the difference between all the little numbers and colors and what's digital and what's not on the dash. I've been driving for 30+ years. Thanks for trying to appease me anyway
Old 03-16-2014, 01:34 AM   #10
Tromatic
What happens when the stick is in "M"?
Old 03-16-2014, 08:43 AM   #11
lorip713
You can use the paddles on the column as you should. When the car is in D it "feels" like it's still in M. You can feel the car revving up to changers the next gear, there is. Hesitancy when you start to slow like you should downshift. I've driven 5 speeds before, I know when to shift. I shouldn't feel those things in D and I didn't for the first 10,000 miles.
Old 03-16-2014, 08:45 AM   #12
Burrcold
Drives: Subaru BRZ Limited
Bring it to the dealer, because you have most of us confused here to the point where you won't get a definite answer.
Old 03-16-2014, 09:03 AM   #13
lorip713
Thank you. I did. I came here because they told me there was nothing wrong.
Old 03-16-2014, 09:26 AM   #14
Burrcold
There probably is nothing wrong then. Besides, if you explained it to them the way you did here, they probably wouldn't know what to look for. Did you ask to go for a test drive with the service tech to show him the issue?
Teaching to drive manual frs bdanisi Scion FR-S / Toyota 86 GT86 General Forum 45 09-01-2013 04:35 PM
Want to test drive Manual FR-S or BRZ... Ann Arbor Nourdmrolnmt1 Great Lakes 5 11-25-2012 10:42 PM
How's the drive using traffic? Manual tranny only gunmetal5 Scion FR-S / Toyota 86 GT86 General Forum 32 10-26-2012 03:21 PM
How to drive manual pezzie AUSTRALIA 35 08-17-2012 08:41 AM
Where to learn how to drive manual.... Saibot CANADA 12 03-13-2012 06:28 PM
