Old 03-11-2014, 09:04 PM   #1
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
MKIII Supra clutch type LSD?
Anyone think of doing this? The 87-89 Supra came with a clutch-type 1.5 way LSD. This can be more desirable to some than the torsen LSD.
I've read that a FRS LSD has been swapped into a Lexus is250. Then i found that the is250 and is300 share the same pumpkin. The supra LSD works in the is300 pumpkin.
So the MKIII Supra LSD should fit, right?
Kotu100 is offline   Reply With Quote
Old 03-11-2014, 09:32 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Why not purchase an clutch type LSD meant for our cars, any part from a Supra is going to be pretty old by now.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-11-2014, 09:37 PM   #3
wparsons
wparsons's Avatar
^^ That would be my opinion too. By the time you buy a used (and old) supra LSD, then rebuild it it'll probably just be cheaper to buy a brand new cusco or kaaz diff meant for our cars.
flickr
akahenry (03-11-2014)
Old 03-11-2014, 10:22 PM   #4
Kotu100
Kotu100's Avatar
Seems like rebuilding a $100-$200 used lsd would be way cheaper than buying a $900+ new lsd.
I was just throwing the idea out there.
Old 03-11-2014, 11:05 PM   #5
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Sorry for the off-topic: but the thing I would love to know...which exact Lexus IS pumpkin, that can directly swap with an FRS, comes with an 4.56 FD, and how to identify it (car model or serial number, etc.).... short FD upgrade on the cheap(junkyard), if it exists.
fooddude is offline   Reply With Quote
Old 03-12-2014, 12:29 AM   #6
Poodles
Drives: 2015 Series.Blue
Don't do it unless you're drifting. Torsen diff is much more advanced and actually handles better (it's also more expensive than a clutch type to make, hence why they were upgrades for the Supra)
Rebuild kit is cheap.
Yes, and those same cusco or kaaz diffs were originally made for the Supra They're also not really much better than a factory one that's been rebuilt with better clutches and springs.
Yep, definitely cheaper and just as effective.
Still, wouldn't do it, the torsen is a far better diff unless you're dedicated to drifting.
The Following User Says Thank You to Poodles For This Useful Post:
Kotu100 (03-12-2014)
Old 03-12-2014, 10:26 AM   #7
wparsons
wparsons's Avatar
^^ That's not entirely true. Clutch diffs work better in a lot of other situations too. Most track junkies prefer clutch LSD's over Torsen LSD's as well.
If you get a wheel in the air with a Torsen diff it behaves like an open diff, which gives you no power to accelerate out of a turn (or into a driveway).
The big benefit to a Torsen is that they have a much longer lifespan before needing major service.
flickr
Muaddib (03-14-2014)
Old 03-12-2014, 10:46 AM   #8
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Helical LSD that can handle 1000hp for these cars are 700$
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 03-12-2014, 01:29 PM   #9
Kotu100
Kotu100's Avatar
Hey Poodles! How's it goin.
I'm sure there's some member that might find this info useful for a cheap drifting LSD.
If you're not one please don't argue that a new one is better. Different strokes for different folks.
Old 03-13-2014, 07:31 PM   #10
Poodles
So then you get one of the Torsens with clutches in them to offset Or have a nice complicated traction control system that uses the brakes to achieve the same goal
The main advantage of the Torsen is in it's name: Torsen = torque sensing. It actually helps you turn instead of fighting you like a clutch based LSD will.
It's funny, the MKIII Supra guys were looking at getting the better Torsens out of the IS because the MKIII specific one (JDM Twin Turbo R with a 1JZ) is a first generation and known to be weak.
Old 03-13-2014, 09:11 PM   #11
Dimman
Kuruma Otaku
Dimman's Avatar
@Jeff Lange
Has numerous, informative posts on this. Including part numbers.
Maybe do a search with his user name and lsd related keywords.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Hawaiian (03-14-2014)
Old 03-14-2014, 01:46 AM   #12
Poodles
Yes, Jeff is well known by me
*waves at Jeff and Kotu100*
Old 03-14-2014, 02:59 PM   #13
Dimman
Kuruma Otaku
Dimman's Avatar
Supramania?
He's already posted up some really detailed information here on diff interchange between Supras, IS and 86s.
Because titanium.
Old 03-15-2014, 04:53 AM   #14
Poodles
Supramania?
Yep, Supramania (same screen name there as here )
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
MKIII is @ Pebble Beach RRnold FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 08-25-2011 10:08 AM
Scion FR-S (MKIII) Coupe/Hatchback/Convertible in color! Allch Chcar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 76 07-01-2011 12:43 PM
Color Swap Request MkII and MkIII xantonin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-20-2011 10:55 PM
