Old 03-11-2014, 01:28 AM   #1
jkr
jkr's Avatar
Drives: '13 frs
nigel jdm fog lights wiring
what green wire is he specifically referring to in this video ?
[ame="http://www.youtube.com/watch?v=o1f23t745Vg"]Nigel-JDMParts Fog Lights - YouTube[/ame]
jkr is offline   Reply With Quote
The Following User Says Thank You to jkr For This Useful Post:
ringo16 (04-20-2015)
Old 03-11-2014, 10:33 AM   #2
jonzhuxD
Drives: Ultramarine FR-S
I think he means the switch is powered via the ignition switch so when you turn your key, the switch can be enabled and when the switch is on it turns on the relay which in turn turns on the fog lights. As for the wire, I believe he means the green ignition wire
jonzhuxD is offline   Reply With Quote
The Following User Says Thank You to jonzhuxD For This Useful Post:
636 (04-01-2014)
Old 03-11-2014, 12:13 PM   #3
jkr
jkr's Avatar
Drives: '13 frs
I popped it open and there is a cluster of green and multicolored wires....
Old 03-11-2014, 01:35 PM   #4
jonzhuxD
There should be a connector right underneath the keyhole/lock cylinder bit with I think 8 wires? Or something like that, 8 or so thicker wires, there should be a wire that's mostly green with a thin orange stripe and that's the one you want to tap into
jkr (03-12-2014)
Old 03-12-2014, 01:01 AM   #5
mjreynolds2
mjreynolds2's Avatar
Drives: Scion FR-S Asphalt
I purchased the same fog lights but spliced mine directly to the radio, took out the USB port since I use Bluetooth and the fog light switch fits perfectly and locks in place.
mjreynolds2 is offline   Reply With Quote
The Following User Says Thank You to mjreynolds2 For This Useful Post:
ringo16 (04-17-2015)
Anyone else have problems with nigel-jdmparts.com??? xDanger_208x User/Vendor/Sponsor Reviews, Feedback, Comments 32 03-31-2014 05:51 AM
Nigel JDM Clear Sidemarkers gatorbushmen Exterior Parts (Aero, Lighting, Etc.) 3 12-15-2013 04:31 PM
Nigel JDM-Parts post_break User/Vendor/Sponsor Reviews, Feedback, Comments 55 10-10-2013 05:35 AM
Nigel-JDM Parts Trojan_SC User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-24-2013 02:34 AM
FS: Nigel fog light harness Manny4115 Exterior Parts (Aero, Lighting, Etc.) 3 04-09-2013 12:21 AM
