Old 03-10-2014, 09:48 AM   #1
Chattanooga FR-S
Chattanooga FR-S's Avatar
Drives: Monogram Firestorm
Test drive a preordered car?
So, I have driven the FR-S that the dealer already has on the lot (twice), but then ordered the Monogram... When it arrives, hopefully this week, I should still drive it before signing papers, right? Just to make sure something's not wrong with it? This is my first time buying a car by ordering it.
Thanks!
Chattanooga FR-S is offline   Reply With Quote
Old 03-10-2014, 09:52 AM   #2
Timmy_Jones
Spun
Drives: 23' Supra
Always drive it.
Timmy_Jones is offline   Reply With Quote
The Following 2 Users Say Thank You to Timmy_Jones For This Useful Post:
Chattanooga FR-S (03-10-2014), Prog (03-11-2014)
Old 03-10-2014, 05:41 PM   #3
humfrz
Yep, a good idea to take it for a short drive. Also, check it over for any damage. Check the tires pressures.
I always check the oil level. Why? Just because I always check the oil level after my car has been to a dealership ......
humfrz
Old 03-10-2014, 08:29 PM   #4
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
It wouldn't be a bad idea to take it around the block as part of YOUR pre-purchase inspection. Any salesman with a brain isn't going to object, especially not with a sale that close to completion.
Slysdexia is offline   Reply With Quote
The Following User Says Thank You to Slysdexia For This Useful Post:
Old 03-10-2014, 08:38 PM   #5
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I did the same thing, but had a chance to drive a friend's first. They will let you drive the car when it comes in, you can always walk away if you don't want it and they should rip up the deposit you left them.
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Old 03-11-2014, 02:38 AM   #6
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
It's not a huge deal, they will check the car in dealer inspection. I would make sure to tell them not to drill the front bumper if you live in a front plate state.
The Following 2 Users Say Thank You to BlaineWasHere For This Useful Post:
Chad86 (03-15-2014), Chattanooga FR-S (03-11-2014)
Old 03-11-2014, 06:34 AM   #7
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
I'd not only drive it but go over every inch of it with a fine-tooth comb. Document any damage or anything you don't think is right, especially any body or paint damage. Once you take delivery it's your word against theirs.
I found some minor scratches under the front lip on mine - very common from taking the cars off the trucks. Dealer wasn't going to mention it, you couldn't see it unless you got under the car. They offered to sand and repaint it but I took a $300 discount instead. Figured I'd probably scratch it myself eventually anyhow.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
The Following User Says Thank You to Clembo For This Useful Post:
Old 03-11-2014, 06:41 AM   #8
funwheeldrive
I was very meticulous when I picked up my car. If you're spending +25k, you should make sure the car is pristine in every way.
The Following User Says Thank You to funwheeldrive For This Useful Post:
Old 03-11-2014, 07:35 AM   #9
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Make sure they don't wash it if you're serious about detailing your car... Too many horror stories of dealers screwing up the paint around here when the cars first started arriving in 2012.
Subaru STI :
The Following 2 Users Say Thank You to Kimsey47 For This Useful Post:
Chattanooga FR-S (03-11-2014), Turbo95eg6 (03-11-2014)
Old 03-11-2014, 09:15 AM   #10
Chattanooga FR-S
Thanks everyone. I do not have to worry about the front plate, as TN is not a two plate state, but I did request that the dealership NOT put their lettering on the car, usually stuck on with white letters on the back somewhere.
I guess my plan for now is to go there when they tell me it is ready, look it all over, inside and out, take a photo of the odometer (to get the low mile picture!), and then take it for a quick test drive, listening for any weird sounds, etc.
Now just hurry up and GET here!
Old 03-11-2014, 09:29 AM   #11
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
When I went to the dealership to pick up my BRZ, it was outside with a "Congratulations" sign in the window. I didn't even bother going inside the dealership to find my saleslady. I took advantage of no one being around and went over that the car in great detail. Saleslady eventually noticed me and came outside, which is when I requested the test drive. Like others have said, it would be dumb of a salesperson to turn you down when they're that close to a sale.
Prog is offline   Reply With Quote
The Following User Says Thank You to Prog For This Useful Post:
Old 03-11-2014, 10:16 AM   #12
BlaineWasHere
Grip>Drift
Drives: FRS
I have the opposite approach. It's only a $25K car so if it isn't perfect whatever!
Chattanooga FR-S (03-11-2014), Doughboy (03-11-2014)
Old 03-11-2014, 10:24 AM   #13
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
I did not test drive mine when I went to pick it up. I just had them pull it out from under the shade into direct sunlight so that I could inspect the car.
Only found two things:
1. stupid dealer advertisement sticker on the trunk
2. left over residue from the wrap (all cars are delivered wrapped).
Had both taken care of and was on my way.
Eurasianman is offline   Reply With Quote
The Following 2 Users Say Thank You to Eurasianman For This Useful Post:
Old 03-11-2014, 11:55 AM   #14
Adam Anthony
Drives: 2013 Scion FR-S Base Firestorm
humfrz
This is some of the best advice out there. When I was much younger, I had a first run edition of the Toyota Matrix. Took it in for an oil change. Guess what, the dealer forgot to PUT NEW OIL IN. After that, well, things didn't go so well. SO. IN sum, Humfrz's advice here is on point. Always check your oil level after getting your car from the dealership.
Adam Anthony is offline   Reply With Quote
The Following 2 Users Say Thank You to Adam Anthony For This Useful Post:
Chattanooga FR-S (03-11-2014), humfrz (03-11-2014)
Anyone have both the PS4 AND the One preordered? Liquidsnake Off-Topic Lounge [WARNING: NO POLITICS] 23 09-25-2013 01:54 PM
The FR-S Test Drive Blackfly Scion FR-S / Toyota 86 GT86 General Forum 29 09-19-2012 09:17 PM
FRS test Drive mankarn86 Scion FR-S / Toyota 86 GT86 General Forum 0 06-13-2012 11:15 PM
So I Preordered a BRZ & Then I test drove an FR-S. slizoth Scion FR-S / Toyota 86 GT86 General Forum 3 06-02-2012 04:28 AM
Test Drive brzmass12 BRZ First-Gen (2012+) — General Topics 8 04-12-2012 11:16 AM
