Old 03-09-2014, 07:38 PM   #1
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
8 inch tablet possible?
So I have done some research and found an affordable windows 8 tablet. I def prefer android but let me explain. With a windows 8 tablet your are able to do all your datalogging and tuning right there in the dash. So no more carrying along the laptop. The dell venue 8 is on sale for around 300 on amazon. For all the nexus install guys whats the possibility of installing an 8 inch tablet, will it fit?
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 03-09-2014, 07:48 PM   #2
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Best way to find out is get the dimensions and cut out a piece of cardboard and put it behind your panel, see how much modifying would be required to make it fit, you could also put 2 layers of cardboard to simulate the thickness, (depending how thick that tablet is)
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-09-2014, 09:12 PM   #3
504
504's Avatar
Drives: 2014 86 GTS
I don't think you'll be able to fit many 8" tablets in the oversize double din area. The nexus 7 2013 has a 16:10 aspect ratio making it quite long and relatively narrow and its screen JUST fits height wise. Not many tablets have this "widescreen" aspect ratio and even if there was an 8" tablet with that aspect ratio or even better a 16:9, its screen width may still be too large for the opening in the car. There is also the issue of bezel thickness and fitment of the larger tablet. Anything is possible though, just gotta experiment
504 is offline   Reply With Quote
Old 03-09-2014, 09:59 PM   #4
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
HP Slate windows 7 tablet should fit in just fine. It was roughly around the same size as my nexus 7. Getting to its USB ports though will be a different story since the dash trim would be blocking access to it.
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 03-09-2014, 11:25 PM   #5
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
I tried a samsung 7.7 tab before I got my N7. The 7.7 was too big. You need to find the dimensions of the actual tablet instead of the screen size.
Trashed675 is offline   Reply With Quote
Old 03-12-2014, 11:03 PM   #6
bgibbsunc
bgibbsunc's Avatar
Yea after looking at dimensions I think it is too big. Thanks for the info. too bad there isn't a decent 7" windows tablet.
San Antonio TX
Old 03-13-2014, 12:41 AM   #7
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Yeah, eight inches is gonna be a pretty tight fit in most spots.
XanRules is offline   Reply With Quote
Old 03-13-2014, 01:17 AM   #8
transition
transition is offline   Reply With Quote
The Following 2 Users Say Thank You to transition For This Useful Post:
Creole (03-13-2014), XanRules (03-13-2014)
Old 03-13-2014, 01:25 AM   #9
Creole
Creole's Avatar
Drives: Monogram FRS
It would be nice to fit my iPad mini in there
Build Thread:
Creoles Creation
Creole is offline   Reply With Quote
Old 03-13-2014, 02:17 AM   #10
labskaus
labskaus's Avatar
Drives: Toyota GT86
Will fit ...
labskaus is offline   Reply With Quote
Old 03-13-2014, 04:57 AM   #11
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Anyone to retain the factory nav and a tray or something to hold the tablet for easy removal ?
ucsmfu is offline   Reply With Quote
Old 03-13-2014, 09:38 AM   #12
Creole
Creole's Avatar
Originally Posted by labskaus View Post
Will fit ...
iPad will definitely work lol..
Build Thread:
Creoles Creation
Old 03-13-2014, 09:51 AM   #13
JL_FRS
JL_FRS's Avatar
Drives: 2014 Firestorm FR-S
If you mount the ipad high enough with the back camera pointed forward you could use it as a dash camera.
JL_FRS is offline   Reply With Quote
Old 03-15-2014, 05:02 AM   #14
labskaus
labskaus's Avatar
Drives: Toyota GT86
I would remove the cooling and made a nicerebuild on taht area
8 inch Subwoofer paaji Electronics | Audio | NAV | Infotainment 34 03-13-2020 12:19 AM
WTB: 16 inch wheels dave77 Want-To-Buy Requests 1 01-11-2014 11:08 PM
3 Inch Exhausts? kmbkk Engine, Exhaust, Transmission 9 10-23-2012 02:18 PM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
