Drives: 2013 Ultramarine FRS
Need Coilover Advice Please
Heyo,
Was hoping someone could help out a noob and provide some guidance on some coilover options: I was looking at the KW V3's but am wondering what kind of difference in ride quality I would feel by pushing my budget further? For instance, what would the difference be between the KW V3's and something like TIEN's Super Racing or the Ohlin's Road & Track. Also, I've heard some opinions that the KW's are overpriced for what they actually offer for our platform and was looking for more opinions on the V3's in general as well. Thanks a ton ![]() PS: Turbo + Exhaust on its way later this month as well. |
Drives: 2013 Firestorm FRS
What are you planning on doing with your car? Dd, track etc
Daily Driver + 1-2 HPDE per month
That being said, I'm not looking to win any races so marginal track performance gains (between the V3 and its competitors) are not as important to me as increase damping performance for the street.
I've heard that going from the ~2k coilovers to the more professional $3-4k series you can get BOTH a stiffer and better handling suspension as well as a smoother ride over stock for DD (whereas the KW's only provide the former instead of the latter). |
#5 | |
Comfort level (smooth to less smooth): TEIN SRC > Ohlins R&T > KW CS >> OEM Performance potential and modular use (application based): TEIN SRC >> Ohlins R&T ~ KW CS >> OEM Cost (lowest cost to highest): OEM >>>>>>> KW V3 >>> KW CS ~ Ohlins R&T > TEIN SRC By the way, 2 HPDEs per month is relatively impressive compared to 99% of the guys on the board. I'd go for the best you can get. JRZ RS-Pro if you can do it. |
| The Following 2 Users Say Thank You to CSG David For This Useful Post: | Anthonytpt (03-07-2014), Squishy86 (03-07-2014) |
Thanks David! Do you think you could be a little more specific in the difference I would feel between something like the SRCs and the V3's
More firm (due to spring rates; most people go with higher spring rates on SRCs than V3/CS), but less harsh.
Mind you, the damper settings do need to be dialed into the proper settings for your given spring rates chosen. SRCs and JRZs are offered with your choice of spring rate, within their specified ranges. |
#8 | |
Because compromise ®
Drives: Red Herring
What kind and what size tires do you run? Do you have any other suspension mods?
- Andy |
#10 | |
(Tires: http://www.toyotires.ca/tire/pattern/proxes-t1-sport) |
#11 |
Anyone have any pics of the SRC's on the FRS? From what I've seen the Ohlins R&T pretty much look stock (very small drop) even on the their lowest setting - I'm wondering if the SRC's suffer the same fate.
Also, I saw someone mention a "CSG spec TIEN SRC" -- anyone want to fill me in on this? |
#12 | |
The off the shelf SRCs are really good out of the box. CSG Spec TEIN SRCs are still being developed as we speak. Just to give you an idea of what the TEIN SRCs look on our BRZ and how well it soaks up bumps in video format. Oh and you get to see @CSG Mike beautiful face. [ame="http://www.youtube.com/watch?v=3TChNrfRKVc"]Maxxis Victra RC-1 - Racer Testimonial Video - YouTube[/ame] |
| The Following User Says Thank You to CSG David For This Useful Post: | fooddude (03-07-2014) |
#13 |
I'm about to install V3's on my FR-S. (Currently have on Tarmac 0's)
What I am hoping for is a bit more comfort in a lowered setting, not slammed, but I'm clueless when it comes to changing the damping on them. I supposed I'll start very soft and work my way up. Goal is comfort, with an occasional spirited drive here and there with some of the TX groups. I don't foresee myself tracking anytime soon, but I definitely do not want to throw that idea off the table. As far as the V3's being overpriced, they can be had for under $2000. The extra adjust-ability is what puts them ahead of those height only adjustable coils, at least this is what I am anticipating and hoping for. |
#14 |
Drive From Home
Drives: BRZ STI Performance
I don't get why people always tend to say soft <-> hard for stuff like rebound adjustments, that makes absolutely no sense to me. I think it's should be fast <-> slow.
| The Following User Says Thank You to krayzie For This Useful Post: | CSG Mike (03-07-2014) |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Need a little advice on coilover install | swift996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-01-2014 10:00 PM |
| STX Coilover Advice | ubersoph | Tracking / Autocross / HPDE / Drifting | 30 | 11-01-2013 07:34 PM |
| Need Coilover Advice for combined Street Comfort + Track Use | distracteddev | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 06-23-2013 04:15 PM |
| Spring/Coilover advice | canuckbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-16-2013 07:09 PM |
