Old 03-07-2014, 12:33 AM   #1
distracteddev
Drives: 2013 Ultramarine FRS
Need Coilover Advice Please
Heyo,
Was hoping someone could help out a noob and provide some guidance on some coilover options:
I was looking at the KW V3's but am wondering what kind of difference in ride quality I would feel by pushing my budget further? For instance, what would the difference be between the KW V3's and something like TIEN's Super Racing or the Ohlin's Road & Track.
Also, I've heard some opinions that the KW's are overpriced for what they actually offer for our platform and was looking for more opinions on the V3's in general as well.
Thanks a ton
PS: Turbo + Exhaust on its way later this month as well.
distracteddev is offline   Reply With Quote
Old 03-07-2014, 12:43 AM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
What are you planning on doing with your car? Dd, track etc
Old 03-07-2014, 12:44 AM   #3
distracteddev
Daily Driver + 1-2 HPDE per month
Old 03-07-2014, 12:48 AM   #4
distracteddev
That being said, I'm not looking to win any races so marginal track performance gains (between the V3 and its competitors) are not as important to me as increase damping performance for the street.
I've heard that going from the ~2k coilovers to the more professional $3-4k series you can get BOTH a stiffer and better handling suspension as well as a smoother ride over stock for DD (whereas the KW's only provide the former instead of the latter).
Old 03-07-2014, 12:52 AM   #5
CSG David
CSG David's Avatar
Originally Posted by distracteddev View Post
Heyo,
Thanks a ton
I believe we are one of the few or possibly the only ones on the board that has actual experience with all the setups you have listed. We have been hired to dial the dampers for clients for all of these suspension kits. Based on the specified kits (we can toss in other kits in here if you want just for comparison sake), here's how we would assess the setups when dialed in properly to driver preference:
Comfort level (smooth to less smooth):
TEIN SRC > Ohlins R&T > KW CS >> OEM
Performance potential and modular use (application based):
TEIN SRC >> Ohlins R&T ~ KW CS >> OEM
Cost (lowest cost to highest):
OEM >>>>>>> KW V3 >>> KW CS ~ Ohlins R&T > TEIN SRC
By the way, 2 HPDEs per month is relatively impressive compared to 99% of the guys on the board. I'd go for the best you can get. JRZ RS-Pro if you can do it.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Anthonytpt (03-07-2014), Squishy86 (03-07-2014)
Old 03-07-2014, 12:55 AM   #6
distracteddev
Thanks David! Do you think you could be a little more specific in the difference I would feel between something like the SRCs and the V3's
Old 03-07-2014, 02:16 AM   #7
CSG Mike
CSG Mike's Avatar
More firm (due to spring rates; most people go with higher spring rates on SRCs than V3/CS), but less harsh.
Mind you, the damper settings do need to be dialed into the proper settings for your given spring rates chosen.
SRCs and JRZs are offered with your choice of spring rate, within their specified ranges.
Old 03-07-2014, 03:20 AM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
OEM <<<<<<< KW V3 <<< KW CS ~ Ohlins R&T < TEIN SRC
Fixed
Old 03-07-2014, 08:57 AM   #9
Racecomp Engineering
What kind and what size tires do you run? Do you have any other suspension mods?
- Andy
Old 03-07-2014, 11:07 AM   #10
distracteddev
- Andy
17x8 235 Toyo T1S
(Tires: http://www.toyotires.ca/tire/pattern/proxes-t1-sport)
Old 03-07-2014, 11:51 AM   #11
distracteddev
Anyone have any pics of the SRC's on the FRS? From what I've seen the Ohlins R&T pretty much look stock (very small drop) even on the their lowest setting - I'm wondering if the SRC's suffer the same fate.
Also, I saw someone mention a "CSG spec TIEN SRC" -- anyone want to fill me in on this?
Old 03-07-2014, 12:54 PM   #12
CSG David
CSG David's Avatar
@D1cker has SRCs on his FRS.
The off the shelf SRCs are really good out of the box. CSG Spec TEIN SRCs are still being developed as we speak.
Just to give you an idea of what the TEIN SRCs look on our BRZ and how well it soaks up bumps in video format. Oh and you get to see @CSG Mike beautiful face.
[ame="http://www.youtube.com/watch?v=3TChNrfRKVc"]Maxxis Victra RC-1 - Racer Testimonial Video - YouTube[/ame]
The Following User Says Thank You to CSG David For This Useful Post:
fooddude (03-07-2014)
Old 03-07-2014, 01:12 PM   #13
FR-S Matt
I'm about to install V3's on my FR-S. (Currently have on Tarmac 0's)
What I am hoping for is a bit more comfort in a lowered setting, not slammed, but I'm clueless when it comes to changing the damping on them. I supposed I'll start very soft and work my way up.
Goal is comfort, with an occasional spirited drive here and there with some of the TX groups. I don't foresee myself tracking anytime soon, but I definitely do not want to throw that idea off the table.
As far as the V3's being overpriced, they can be had for under $2000. The extra adjust-ability is what puts them ahead of those height only adjustable coils, at least this is what I am anticipating and hoping for.
Old 03-07-2014, 01:47 PM   #14
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I don't get why people always tend to say soft <-> hard for stuff like rebound adjustments, that makes absolutely no sense to me. I think it's should be fast <-> slow.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
CSG Mike (03-07-2014)
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Need a little advice on coilover install swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2014 10:00 PM
STX Coilover Advice ubersoph Tracking / Autocross / HPDE / Drifting 30 11-01-2013 07:34 PM
Need Coilover Advice for combined Street Comfort + Track Use distracteddev Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-23-2013 04:15 PM
Spring/Coilover advice canuckbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-16-2013 07:09 PM
