Old 03-06-2014, 10:53 PM   #1
mxrider404
mxrider404's Avatar
Drives: 2014 Scion FRS Pearl White 6 Speed
Android Device with Blue tooth
When I first got my FRS I had an iPhone and have since upgraded to an HTC One and I do not have the same blue tooth control with my phone when playing music. I am using the double twist app for my music but I can not browse my music library on the head unit. Any recommendations on apps to use instead or am I doing something wrong?! Being new to both an Android OS and bluetooth audio systems probably isn't helping me any... Thanks!
mxrider404 is offline   Reply With Quote
Old 03-09-2014, 07:06 PM   #2
mxrider404
mxrider404's Avatar
Any ideas?!
Old 03-11-2014, 09:17 AM   #3
mid_life_crisis
Drives: FR-S 10 #103 AT
You aren't doing anything wrong. Keep trying apps and you might get lucky, but I'm pretty sure it's the bluetooth stack in the phone itself. I lost features with my Note2 when AT&T "upgraded" it to 4.3 from 4.1. It used to display Pandora song information but now it always displays the last song I listened to from my library. I've never been able to change albums from the H/U.
Old 03-11-2014, 09:54 AM   #4
Chimera
Drives: FRS
This has to do with the BT drivers on the ROM.
For instance newer drivers tend to give you the choice of either phone sync, or phone and media sync, (both are typically checked by default anyways) whereas older android 2.3 roms only had sync or don't sync, all or nothing.
In most ROMS I have tried, one issue I have observed is the phone only reports the data from the primary player (or default app as set by the ROM) not the actual source playing. so if you play music from several players it might show paused on the HU.
edit: try setting this double twist app as the primary player for your device.
Old 03-13-2014, 09:39 AM   #5
mxrider404
mxrider404's Avatar
I have been trying for several days to find out where to set double twist as the primary (default) player without any success. I am using Android 4.4.2 software version. Any pointers?
Old 03-13-2014, 10:01 PM   #6
Chimera
Drives: FRS
On my current rom it's under settings > general >application manager. Then default actions
Old 04-06-2014, 04:08 PM   #7
WyreNut
Drives: Firestorm Red FR-S
+1
All I get now with pandora is "no title" and "No track" displayed from Pandora...
Thanks a lot, AT&T. :/
WyreNut
WyreNut is offline   Reply With Quote
Old 08-23-2014, 04:40 PM   #8
WyreNut
Originally Posted by WyreNut View Post
+1
WyreNut
UPDATE: The recent OTA upgrade to KitKat returned the proper display from Pandora!
Amazing how such a little fix can brighten my day. :-D
WyreNut
Old 08-23-2014, 11:25 PM   #9
jflogerzi
jflogerzi's Avatar
WyreNut
My LG G3 will not display information I miss this.
Blue tooth drop out brze86 Electronics | Audio | NAV | Infotainment 62 03-13-2014 01:10 PM
iphone IOS 7 blue tooth Garstang Electronics | Audio | NAV | Infotainment 42 11-01-2013 09:15 PM
Recommend a cheap Android device to use for Torque app. theom Engine, Exhaust, Transmission 5 07-08-2013 09:56 PM
Forget the Nav, how is the Bespoke as a blue tooth radio? brillo Electronics | Audio | NAV | Infotainment 9 02-21-2013 03:20 AM
how do you sync an iphone to the blue tooth in the car? pr086 Electronics | Audio | NAV | Infotainment 5 12-06-2012 09:51 AM
