Old 03-05-2014, 09:59 PM   #1
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Help! Stuff coming out of my exhaust. What is it?
As you see in the pictures this fur or whatever it is, is coming out of my exhaust.
I've ruled out the exhaust system (replaced all of it with known good not not spitting out furballs) headers, overpipe, midpipe, axle back, which means it's not coming FROM the exhaust, just though and OUT the exhaust. I'll tell you which exhaust parts I have anyway just in case. Header: JDL UEL catless, Nameless overpipe/frontpipe with high flow cat and helmholtz resonator, stock midpipe, nameless offset axleback.
On the other side I have a Perrin intake to a Innovate supercharger. The only thing I can think of is there's something in the Innovate supercharger, manifold or intake system but I don't have a clue what it could be. I can't imagine it passing through the intake into the combustion chamber and surviving unless it's fire/heat proof material of some sort. Maybe the shop that installed the supercharger dropped something into the engine/manifold and the car is spitting out these chunks of stuff?
Does anyone have any ideas? I have it at a different shop and they're baffled as to why it's coming out and still coming out randomly after swapping exhausts and running it on a dyno.
stockysnail is offline   Reply With Quote
Old 03-05-2014, 10:01 PM   #2
jonbonazza
is there a cat in your exhaust? O.o
jonbonazza is offline   Reply With Quote
The Following User Says Thank You to jonbonazza For This Useful Post:
raul (03-05-2014)
Old 03-05-2014, 10:03 PM   #3
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Heeeere come the cat-back jokes.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
Mad1723 (03-05-2014)
Old 03-05-2014, 10:08 PM   #4
jonbonazza
I didn't even think of that... no pun intended i guess... lmao
Old 03-05-2014, 10:12 PM   #5
stockysnail
Just the tip
I have one high flow cat but all of the exhaust components were removed and replaced with a exhaust system that was known to not spit out fir, which was completely catless. Still spat out that stuff. (See original post)
Old 03-05-2014, 10:13 PM   #6
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
Muffler packing is disintegrating and blowing out. That or you have rodents making nests in your exhaust.
That's what happens when you get rid of your cats, the mice move in.
turbocat is offline   Reply With Quote
The Following User Says Thank You to turbocat For This Useful Post:
Travisty75 (03-05-2014)
Old 03-05-2014, 10:18 PM   #7
humfrz
Well, stockysnail ..... that's weird.
Did you actually see it coming out of your car's exhaust, or was it on the floor behind the exhaust .. ??
If it came out of the exhaust, maybe some little critter crawled up in there looking for a warm, dry place to hang out ... ??
Oh, heck, I'd just take that machine up on the highway, open up the boost and give it a good blowing out.....
humfrz
Old 03-05-2014, 10:20 PM   #8
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Fiberglass packing more than likely.
Have you also noticed your exhaust getting louder as of late? Chances are that you have a cheap resonator somewhere in your system, the perforated core split or corroded, and now you're losing the guts that keep things quiet(er).
If you don't mind your exhaust getting louder, don't worry about it. If it is the resonator, you may pick up a bit of rasp.
Travisty75 is offline   Reply With Quote
Old 03-05-2014, 10:23 PM   #9
stockysnail
Just the tip
I guess it's possible that my car just makes muffler packing come out not matter which exhaust is on it. Seems unlikely though if we completely replace the exhaust with a different one that was on a car that has more hp and boost than mine, yet still poops out that stuff. Not sure if I can think of anything else.
Old 03-05-2014, 10:25 PM   #10
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
Reinstall cats, problem solved! No more rodents.
Sorry I'm done.
Other point is that catalytic converters act as flame arresters. When you remove them you allow the flames travel through your exhaust. Usually on WOT to off throttle overrun condition. The flames are BBQing the muffler packing.
Yamaha_R6 (03-05-2014)
Old 03-05-2014, 11:07 PM   #11
Malt
Drives: 2015 WRX
If something like that went through your engine you'd have much larger problems than just fur coming out of your muffler. Its exhaust packing
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
stockysnail (03-06-2014)
Exhaust stuff for sale in CO gdrider77 Rocky Mountains / Great Plains 0 02-20-2014 06:51 PM
White smoke coming from the exhaust. hansthegerman Engine, Exhaust, Transmission 17 10-02-2013 05:23 PM
FS: OEM exhaust, headers more oem stuff Baddon86 Engine, Exhaust, Bolt-Ons 0 09-09-2013 11:23 AM
Smoke coming from the Exhaust peachsnow Scion FR-S / Toyota 86 GT86 General Forum 18 12-09-2012 03:59 AM
FRS coming with TRD exhaust?? oso_25 Engine, Exhaust, Transmission 26 09-24-2012 04:32 AM
