Old 03-05-2014, 09:07 AM   #1
mid_life_crisis
Drives: FR-S 10 #103 AT
Question for A/T owners on shift cover.
When you look at the cover that has the gear indicators on it, if you look above Park (towards the dash), there is a small rubber plug. If you take the cover off and look from underneath, it looks like there is a place for a switch or pushbutton that would project through the opening if that plug wasn't there.
Does anybody know what it was supposed to be for?
Old 03-05-2014, 09:38 AM   #2
TwinturboCamry
Drives: 4 wheels
Overdrive override
TwinturboCamry is offline   Reply With Quote
Old 03-05-2014, 09:47 AM   #3
mid_life_crisis
Originally Posted by TwinturboCamry View Post
Overdrive override
That seems reasonable. How do you know that?
Old 03-05-2014, 09:50 AM   #4
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
if u remove the cover its just a hole i assume? if so its a shift release, so if ur battery dies u take a small screwdriver or example, push it in there and then u can shift the car and move it
lbroskee is offline   Reply With Quote
Old 03-05-2014, 09:51 AM   #5
TwinturboCamry
Drives: 4 wheels
That's button is in the exact same place on 99% of cars. I had to replace that cover on my camry and the part was over drive override cover. It covers a small button
Old 03-05-2014, 09:55 AM   #6
Mikem53
Drives: FR-S 6MT
That should be the interlock override.. If your some reason.. The electronic stop that keeps you from moving the selector gets stuck or won't operate.. You can stick a flat edge in there and put the car in gear..
Mikem53 is offline   Reply With Quote
Old 03-05-2014, 10:21 AM   #7
mid_life_crisis
I'll have to look again. From underneath it didn't look like there was anything there.
Old 03-05-2014, 01:34 PM   #8
mid_life_crisis
There is a large square button below it. I held it down with the motor off and was able to move the shift lever.
Old 03-05-2014, 11:27 PM   #9
lbroskee
lbroskee's Avatar
ya i thought so. just unlocks ur gear box basically so u can put in Nuetral and push
Old 05-05-2014, 10:54 PM   #10
MysteryMachine
MysteryMachine's Avatar
Drives: 2014 SWP BRZ, 2002 Bugeye OBS
weird mine never had a plug... just a hole and I got it brand new with just a couple miles
MysteryMachine is offline   Reply With Quote
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Series 10 owners, question on DRL rskdsk Scion FR-S / Toyota 86 GT86 General Forum 6 09-30-2013 09:46 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 09:48 PM
Question for auto FR-S/BRZ owners Sport-Tech Engine, Exhaust, Transmission 8 05-21-2012 01:06 PM
