Drives: 2014 Monogram FR-S White MT
Taillight condensation
I've got my car garaged and only take my car for spins when the weather is nice and haven't really parked it outside for long periods. I'll probably continue driving like this for a while since I've got another beater car that is reliable.
Under what conditions does taillight condensation show up? Parked overnight? Or when you just go cruising on a chilly night? |
#2 | |
Drives: FRS
The stock gaskets eventually leak. Search the threads for a permanent fix. ![]() ![]() ![]() CERBERUS |
Thanks
Last thing you want is getting pulled over for a shorted out tail light when you got body bags in the trunk
Drives: Asphalt FR-S
I finally had condensation in mine after over a year of having my car. Had dealer replace it.
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
Im on my second set of tail lights now, they are leaking again.
Im going to apply the afore mentioned fix this time around. Shit is getting old.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#7 | |
Drives: FRS
Some aftermarket tails have a better sealing gasket, but eventually they leak because of the constant water erosion (as in the Grand Canyon). The solution is to divert the water flow away from properly sealed gaskets. ![]() ![]() CERBERUS |
Thanks for the heads up. Thought maybe it was just a defect on the seal for the OEM tails.
did they fix it in the 2014 models?
#10 |
Drives: 2005 Toyota Camry
#11 | |
The "fix" is just torquing the bolts to a lower spec with new taillights, but unless they redesigned the housing this problem may eventually come back. A more permanent fix is outlined above, but could possibly cause warranty issues if you're still under the basic warranty. -alex |
#12 |
Drives: '13 FR-S
#13 |
Thanks
#14 |
Drives: FRS
silicone works great and comes off easy if you need to apply it to divert water away
| headlight/taillight condensation | Moe23 | Issues | Warranty | Recalls / TSB | 6 | 01-22-2014 02:27 PM |
| Taillight condensation.... again. | kroarke | Issues | Warranty | Recalls / TSB | 1 | 07-03-2013 01:47 AM |
| Ugh - Possible taillight condensation | Crackseed | Hawaii | 18 | 04-23-2013 10:38 PM |
| Taillight Condensation Issues... Again... | Kuneff | Issues | Warranty | Recalls / TSB | 3 | 12-12-2012 04:21 PM |
| Anyone Else gotten taillight condensation? | clevrname | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-04-2012 11:28 AM |
