Old 02-28-2014, 10:01 PM   #1
Visxco
Visxco's Avatar
Drives: BRZ 2014 SWP
245/40/18 Stock Susp. Will I rub?
Anyone know? Will I have to roll my rear fenders?
Visxco is offline   Reply With Quote
Old 02-28-2014, 10:20 PM   #2
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Depends on the offset. With 45mm you should barely clear with slight chance of rubbing the springs with the wheels turned, if you did not add any negative camber. 40mm with 2.6* of camber will rub slightly, from my experience.
Old 02-28-2014, 11:28 PM   #3
Powersfrs
Drives: Frs
I ran(on pothole infested LA streets) 255 40 offset 18s for a week before installing my kw no rubbing...
Powersfrs is offline   Reply With Quote
Old 02-28-2014, 11:38 PM   #4
DAEMANO
Time Traveller
THIS
Especially in the front.
The rears will clear with no problem.
In the front offset is just about everything with this tire widths 245+ in size, especially on 9" wheels. You're shooting for 45-35 offset with 9" wide wheels on 245-255. Make sure to have a pair 3mm hubcentric spacers handy just in case you rub due to the difference in tire width from one mfg to another. Once again this is specifically in the front. The rears will clear no problem.
Old 03-01-2014, 09:33 AM   #5
AGM6789
Drives: SWP 86 GTS 6MT
Why not go 245/35/18? Rolling diameter remains the same as stock and absolutely no rubbing
AGM6789 is offline   Reply With Quote
Fr Susp noise on gravel or bad pavement. Ozzman Issues | Warranty | Recalls / TSB 17 11-03-2015 06:29 AM
TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar BumpersFRS Exterior Parts (Aero, Lighting, Etc.) 1 01-11-2014 03:42 AM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-20-2012 11:10 PM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 08:50 PM
Whiteout Project Underway-Five Axis Kit Cusco Susp with TSW Wheels Norcalscionchamp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 08-19-2012 08:33 AM
