Old 09-22-2013, 03:39 PM   #1
Ozzman
Drives: old
Fr Susp noise on gravel or bad pavement.
When driving on gravel roads or cracked/shitty pavement at speeds under 15 mph a rattle like sound emanates from the underneath the front of the vehicle, It can also be felt as a sort of vibration through the floor board/gas pedal and somewhat through the steering wheel.
I've checked under the car and the ball joints seem tight, along with all suspension mounting bolts and skidplate bolts. The swaybar endlinks do not appear to have any looseness.
So what am I hearing/feeling and has anyone else experienced this? I kinda wonder if the skidplate is amplifying some vibrations induced in the suspension.
Ozzman is offline   Reply With Quote
Old 09-22-2013, 05:53 PM   #2
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I have a "crushed rock" driveway and I hear the same thing. It is quite annoying and makes me wonder where the play is.
Thorpedo is offline   Reply With Quote
Old 09-22-2013, 06:27 PM   #3
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Guys don't worry, this is most likely ABS and / or traction control doing its best to maintain traction. You may also notice the lights on the dash in the event .
Feel free to research how advance technology has come on these systems to get a better understanding. Of course if you feel something is wrong seek your local dealer for answers.
I hope this helps.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 09-22-2013, 06:55 PM   #4
Thorpedo
The SquadWhisperer
Nope, I feel play in the suspension somewhere. (can't speak for the OP though) I am well aware of what the ABS/trac feels like. It does it whether i am coasting, accelerating or braking. I run in autocross commonly and I am more than aware what the technology you speak of feels like when it is in action haha.
I hope this helps.
Old 09-22-2013, 07:40 PM   #5
Wo6M
Wo6M's Avatar
Then I suggest a lift , gloves and a sturdy hand !
Good luck fixing it friend
Mods:
Old 09-22-2013, 08:20 PM   #6
Thorpedo
The SquadWhisperer
Thanks As the op stated I can feel it in the steering. Perhaps there is an extremely soft bushing in the front compressing to the point where metal can collide with metal?
Old 09-22-2013, 08:26 PM   #7
Ozzman
Drives: old
I hope this helps.
No it's not. It occurs when rolling, even in neutral without any input into any pedal, driving straight ahead.
Old 09-22-2013, 08:28 PM   #8
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
The black fiber board is held by fasteners that allow movement. Removing each faster and placing a fiber washer solved it for me.
448hpsti is offline   Reply With Quote
Old 09-22-2013, 08:28 PM   #9
Ozzman
Drives: old
Maybe, I'm just trying to get feedback from more people who have driven their toyobaru in those situations to see if it's normal or not.
Old 09-22-2013, 08:30 PM   #10
Ozzman
Drives: old
Did that and put rubber washers under the bolt heads where there was loosness in the fiber board mounting. Made no difference.
Old 09-25-2013, 12:33 AM   #11
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Not much see goes thump, I had a shock top bot that I had to retorque but most myher soundscape just rattles
Old 09-25-2013, 01:09 PM   #12
onepremiere
Drives: Space Shuttle
posted this in another thread with a similar issue.
check nuts on the bracing under the hood, but do not tighten them anything over 15lbs other wise you will sheer the stud off.
mine were loose and shifting under load. sounded like I had toasted a ball joint.
i added some rubber washers under the brace where it meets the body just in case. haven't heard anything since.
onepremiere is offline   Reply With Quote
Old 09-25-2013, 07:44 PM   #13
Ozzman
Drives: old
Thanks, I'll check that out.
Old 02-10-2014, 08:18 AM   #14
AJ
Drives: ’13 Asphalt FR-S
Have this same issue. I’ll check the braces and report back.
AJ is offline   Reply With Quote
Gravel roads in the styx regal Scion FR-S / Toyota 86 GT86 General Forum 37 08-04-2013 09:54 PM
Whiteout Project Underway-Five Axis Kit Cusco Susp with TSW Wheels Norcalscionchamp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 08-19-2012 08:33 AM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 05:22 PM
CUSCO TOYOTA 86 Rally Car test on the gravel road ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-29-2012 07:22 PM
