Old 02-25-2014, 12:55 AM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
HIDs? Bend your squirrel finders
There have been questions about squirrel finders in the past so I'd like to share my experience. First of all the squirrel finders are the metal tabs you feel when you stick your finger in the headlamp projector. In order to bend them for HIDs you need more force than your fingers; what I did was stick a flat head screwdriver in and push with a decent amount of force (you are moving metal) for just one push, checked my lights to see if it was satisfactory, if it wasn't then rinse and repeat. Keep in mind HIDs take a few seconds to warm up so make sure you let it sit for a bit before making judgements.
Please no true retrofit or gtfo posts, this is simply for informational purposes and to help make sure no one is being blinded by one of us.
Here is the end results after one iteration (before and after). Beam taken from approximately 3 feet away (I don't have anywhere flat to measure from 25 feet).
Before: http://imgur.com/96I3SDc,Qq5FQjh#1
After: http://imgur.com/96I3SDc,Qq5FQjh#0
Yes it is the same spot. Amazing what bending a piece of metal can do.
l0aded is offline   Reply With Quote
Old 02-25-2014, 12:59 AM   #2
l0aded
Addicted
l0aded's Avatar
I can take some better pictures if people are wondering about the contrast, my camera focus is slightly off for in depth analysis. I can tell you from actually looking at it there is a substantial improvement though I'm sure it's obvious from the pictures.
Old 02-25-2014, 01:05 AM   #3
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
The difference is noticeable for sure and ur pics capture that.
The only problem with ur pics is that they are in a link and not posted on here using say the IMG code from photobucket. So many people are lazy and will complain about having to waste 1/2 a sec from their lives to click on a link lol.
FRSfan111 is offline   Reply With Quote
Old 02-25-2014, 01:14 AM   #4
retrosmiths
Drives: Scion FR-S Whiteout
I have done the same, but I stuck a wad of those cement sticks in the gap just below the cutoff shield. Worked better and did not messed up the alignment.
Although I did opened mine up, because I was gonna paint the chrome assembly inside.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 02-25-2014, 01:17 AM   #5
l0aded
Addicted
l0aded's Avatar
I'm confused don't you have a morimoto retrofit? Is that still necessary?
Old 02-25-2014, 01:23 AM   #6
retrosmiths
Oh sorry, my signature is old.
I sold my retrofitted headlights and went back to stock ones (modded with the above method) because they have more foreground light which I prefer (even though most HIDP members are saying it makes you focus on the front of the car rather than on the road).
2013 Scion FR-S
The Following User Says Thank You to retrosmiths For This Useful Post:
jwSubMOA (03-01-2014)
Old 02-25-2014, 08:01 AM   #7
frslee
Just drive it
Drives: 13' FR-S
Retrofit is the way.... just kidding! ha
Yes, I did the same thing the other night and it did improve the cutoff a lot. I have a skinny finger so I was able to stick it and push it down all the way. I did make a thread before about pulled over by police for having too bright headlight. I'm now using 35w and it's less brighter than the one I used to use, so don't worry people, I'm good now.
DDM tuning bulbs are not really consistent with their colors, so I'm waiting on morimoto 4300k bulb. DDM's 4500k has some bluish light, which doesn't make sense. Let's see how the new bulbs do.
frslee is offline   Reply With Quote
Old 02-25-2014, 08:58 AM   #8
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
FYI HIDs usually have a little light above the line to light up signs like on the highway, etc.
Books is offline   Reply With Quote
Old 02-25-2014, 09:25 AM   #9
frslee
Just drive it
Drives: 13' FR-S
yeah that makes sense, but howcome there's no light present on other factory hid?
I've seen tsx, venza, rx, a4 hids and didn't see any light above the cutoff line though.
Old 02-25-2014, 09:36 AM   #10
HunterGreene
Hail Magnet
HunterGreene's Avatar
HIDs in general are bright enough in the stock housings that they don't need much light above the cutoff line. There is enough light diffused that it will still light up signs more than adequately.
It has priests in it?
Old 02-25-2014, 01:13 PM   #11
l0aded
Addicted
l0aded's Avatar
Lol I remember that thread. You're the reason I put up that disclaimer.
The Following User Says Thank You to l0aded For This Useful Post:
frslee (02-25-2014)
Old 02-25-2014, 01:49 PM   #12
NemeGuero
This should be stickied with the amount of pnp HIDs on this forum.
Good job.
NemeGuero is offline   Reply With Quote
The Following User Says Thank You to NemeGuero For This Useful Post:
l0aded (02-28-2014)
Old 02-25-2014, 02:07 PM   #13
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
Does anyone have a picture of the actual squirrel finders? The only thing I see is 1 large metal tab that I can reach with my finger. Is that all I need to bend down? I get flashed by almost every car on the road since installing a 6000K PNP HID kit. I might just take it out all together if I can't get the squirrel finders to help.
Jlturner is offline   Reply With Quote
Old 02-25-2014, 02:27 PM   #14
HunterGreene
Hail Magnet
Its better if you just do it by touch, but if you put your finger in the socket, the first piece of metal that you hit is likely the SF. Feel around inside, should have a little springy give to it (otherwise that's just another piece in the assembly). Follow the instructions above and push it down.
The Following User Says Thank You to HunterGreene For This Useful Post:
Jlturner (02-25-2014)
Squirrel noise >1K RPM, Video attached SubieNubie Issues | Warranty | Recalls / TSB 9 11-26-2013 11:11 PM
Modding squirrel finder wbradley Cosmetic Modification (Interior/Exterior/Lighting) 6 07-10-2013 02:53 AM
Help! Squirrel finder issue! Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 13 03-01-2013 01:26 PM
Hids Sh4rp CANADA 3 07-30-2012 12:25 PM
How to make the dealership bend over backwards? Kiteless Scion FR-S / Toyota 86 GT86 General Forum 48 10-30-2011 05:05 PM
