Old 10-26-2012, 09:05 AM   #1
wbradley
Sarcastic SOB
wbradley's Avatar
Modding squirrel finder
Anyone done it on the FR-S yet?
I instaled HID kits in my FR-S and my xB as well 2 weeks ago and am unsure whether the glare is an issue. Tried looking at all angles and parking one car facing the other etc and AFIK they are OK but if there's even a bit of excessive glare I want to correct it.
I would be interested in knowing if I can reach inside the lamp enclosure and manually bend it, do I need a needle nose or bent needle nose to do it or will hands suffice? Does the enclosure need to be baked open (no way I'll do that!!).
Old 10-26-2012, 10:58 AM   #2
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
You really need open the lights and install the correct projectors. However this might help...
Originally Posted by Wes View Post
Those are your squirrel finders reflecting light, take out the HID bulbs and stick your finger into the housing and you should find these metal plates and just push them down as much as you can til it bottoms out and it should eliminate them. If not those areas will glare at other people.
for more info...
http://www.ft86club.com/forums/showthread.php?t=20728
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-27-2012, 11:45 AM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
Update: Pulled out the H11 Xenon lamps and stuck my finger in the hole...
waddya know, on the bottom you can feel a thin steel piece parallel to the ground that reflects some light up. I just bent it down all the way with my finger and voila...totally dark above the cutoff!!
Now, on my xB it appears they get the squirrel catcher effect simply by a flattened area molded into the reflector itself. In other words it can't be bent down. Through microsurgery or opening the whole light assy. one could paint the bottom plate area black but that's WAY too much work/risk for a very mildly annoying issue.
Old 05-13-2013, 12:46 AM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Need quick diy help. HID install and bending the squirrel finder down. I bent down the thin tab close to the back that is already angled sliightly down with room under it (not totally flat). It seems like its not a clean cutoff still but big glare. Did i bend the right part or should I have bent down in front of it?
Old 07-09-2013, 02:07 PM   #5
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Yesterday I installed my HID kit and bent down the tabs (toward the back of the housing) and got good results... not a super clean cutoff but much better than it was before.
Avo1789 is offline   Reply With Quote
Old 07-09-2013, 03:16 PM   #6
finch1750
finch1750's Avatar
Thanks. I did too. Then I went and did it much harder along with adjusting the headlight and got a pretty good cut off. Once you bend it all the way (you think) press down harder.
Old 07-10-2013, 02:53 AM   #7
retrosmiths
Drives: Scion FR-S Whiteout
Bending those might give you a crooked cutoff.
I retrofit headlights for a hobby and I have this pair with the squirrel finders blocked with epoxy gum. My test HID kits will be coming in tomorrow so wait for my pics here.
PS: I have another pair with a proper HID projector installed. The light output blows the stock away.
-Sent from outer space
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
EU to Ban Modding frosty86 Scion FR-S / Toyota 86 GT86 General Forum 29 11-04-2012 12:56 AM
Not modding - wheels and suspension available Z86 AUSTRALIA 0 10-08-2012 09:48 PM
Car Finder feature on Remote eriktherod Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 07:23 AM
Hachi's Ninja Forum modding Giccin Off-Topic Lounge [WARNING: NO POLITICS] 147 01-09-2012 08:25 PM
