Drives: Scion FRS asphalt
Borla uel advice
So I bought borla uel headers and installed them myself. A few days later I started hearing an exhaust leak and think I may not have torqued that one tricky bolt enough. Anyone that has done an install themselves knows which bolt it is lol the one on the driver side right next to the bend. If I had a picture I'd post it. For the record I used a flex joint socket to get to the bolt the first time. So my question would be how did you go about tackling the nut? Any tricks to it?
Fanboy
Drives: 2013 ultramarine frs
Did you reuse the gaskets or replace them? I'd suggest the grimmspeed gaskets once you figure out how to tighten that one nut.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
Drives: 2013 FR-S White out
I've had no issue yet but I got new gaskets when I did the install
Perrin drop in filter Genome Tuning Aluminum resonator delete Borla UEL header motiv concepts over pipe megan racing resonated front pipe invidia q300 cat back and more to come
Not trying to be a ****
Drives: BRZ - 6MT - GBS
I re-used gaskets but I was also very careful not to over torque bolts which can also give you a leak. I know it can get tight down there but maybe try to get a torque wrench? I know I got mine on most of the nuts/bolts.
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
Tech Master / Car Geek
Drives: 2013 AT Hot Lava FR-S
I reused my gaskets and made sure to use a smaller torque wrench with a long and skinny extension. I stuck the extension in between the header pipes then put the socket on the extension.. worked well for me. I also made sure to tighten the bolts evenly and opposite, kind of like putting on a tire, but that was me being extra careful on my first header install.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys Borla: UEL Header Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT -= OFT - Stage 2 UEL E85 - fine tuned by me. =- |
I feel like resusing a header gasket is a terrible idea. Maybe I am crazy.
Drives: Passat
you're crazy! Really though you just have to be careful.
Drives: 2013 Raven Black FRS
I've reused the stock gaskets numerous times on some friends cars with no issues. I usually snug that center (hard to get bolt) down first before the 2 outers.
| Borla UEL Header : Need some opinion/advice. | Ray_32 | Engine, Exhaust, Transmission | 3 | 10-28-2013 11:53 AM |
| I need some advice | The Robot Cow | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 04-06-2013 03:43 PM |
| Advice | EDCOVEY | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 12-10-2012 08:16 AM |
| Need advice | FRSMAK86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-06-2012 05:39 PM |
| FR-S or BRZ? Need some advice | Davie Dynamite | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 07-13-2012 10:47 PM |
