Old 02-24-2014, 01:14 PM   #1
bobka7914
Drives: ‘22 BRZ, ‘18 Crosstrek
Disable Sound Generator With Minimal effort
I will be picking up my new '14 BRZ Limited this Friday.
Would like to disable sound generator with minimal effort- Could I just plug the hole under carpet in passenger's footwell using a 7/8" nylon plug?
bobka7914 is offline   Reply With Quote
Old 02-24-2014, 01:23 PM   #2
AznBRZer
Drives: 16 CBS WRX Limited
Yup. You could also take the plug from the glove box for the power adapter and use that as well.
AznBRZer is offline   Reply With Quote
The Following 3 Users Say Thank You to AznBRZer For This Useful Post:
azngolfur (02-24-2014), JohnJuan (02-25-2014), JS + BRZ (02-24-2014)
Old 02-24-2014, 04:33 PM   #3
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
This is the cheapest and easiest way to do it.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 02-24-2014, 04:35 PM   #4
JS + BRZ
Drives: 2010 MS3
This is what I did. The difference in sound is huge on high rpm. haha pretty cool stuff.
JS + BRZ is offline   Reply With Quote
Old 02-24-2014, 06:07 PM   #5
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Others have posted saying that very good plugging of the cabin hole is just as good for noise reduction as deleting the entire sound tube itself. So plugging should do the trick, but you'll still have that unsightly tube under the hood. Add rubber or foam behind the plug to be more effective.
blue cat is offline   Reply With Quote
The Following User Says Thank You to blue cat For This Useful Post:
SirBrass (02-24-2014)
Old 02-24-2014, 06:13 PM   #6
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
You can simply plug the hole with a 3/4" nylon plug, and with a flathead screwdriver and a 10mm socket you can take out the sound tube and plug the hole with a 1.25" pvc plug (not cap!). Can be done in < 5 minutes.
^GT5 Replay Photo Mode^
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 01:26 AM
Sound generator delete for $1.06 PineappleFriedRice Engine, Exhaust, Transmission 13 11-10-2013 12:28 PM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 04:25 AM
Removing the sound generator tube Jcadillo Scion FR-S / Toyota 86 GT86 General Forum 2 07-11-2013 10:59 PM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 11:31 AM
