Old 02-18-2014, 12:36 PM   #1
troek
troek's Avatar
Drives: 2012 Toyota 86
Gutting the OEM seats?
As a budget alternative to lighter seats, does anyone have any idea how much weight could be saved by removing the airbags/electronics in the OEM seats?
Old 02-18-2014, 12:41 PM   #2
CBR600RR
Drives: Raven Black
5-10lbs each seat maybe???
you will never notice that difference in weight translate into increased performance... IMO, leave them the way they are, shave weight elsewhere
Old 02-18-2014, 02:37 PM   #3
canu_50
canu_50's Avatar
Drives: Scion fr-s
If you are on a budget and tracking the car.. playing with safety item to shave weight is a very bad idea....
canu_50 is offline   Reply With Quote
The Following User Says Thank You to canu_50 For This Useful Post:
supramkivtt2jz (02-18-2014)
Old 02-18-2014, 02:52 PM   #4
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Agreed. I would look elsewhere to save weight. For a dedicated track car, you could remove the audio equipment and a/c to save a lot more than 10 lbs.
FReSh is offline   Reply With Quote
The Following User Says Thank You to FReSh For This Useful Post:
Old 02-18-2014, 08:29 PM   #5
troek
troek's Avatar
I understand the safety concerns, but its no less safe than swapping to buckets, which are available through the dealership. But if the assemblies only weight a few pounds, then its not really worth the trouble i suppose. But 10 lbs? Do that in 10 areas of the car and thats 100lbs.
Old 02-19-2014, 09:34 AM   #6
canu_50
canu_50's Avatar
Drives: Scion fr-s
Bucket seat are made stronger, and in a different fabric to absorb impact.
And when i say do touch the safety equipement, it is because it works as a whole.. Either you take off everything and make a cage, bucket, harness, head restraint seat, or nothing.. This is my opinion when it comes to safety..
Old 02-19-2014, 10:20 AM   #7
utekineir
blowhard
Drives: frs, project forester
seat airbag wasn't that heavy,
you're going to have to remove the seat belts and inner brake pads if you really want to feel a difference
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
canu_50 (02-19-2014)
Old 02-19-2014, 10:31 AM   #8
troek
troek's Avatar
so, i should still be able to stop with just the outer brake pads then? sounds good. but then again now that i think about it, driving my car at a race track seems too unsafe anyway, so im gona stop doing that altogether. oh and thanks for all the posts about how much the airbags weigh. oh and where can can i get ahold of this fabric that absorbs impact? sounds pretty ground braking.
The Following User Says Thank You to troek For This Useful Post:
Surok (02-26-2014)
Old 02-19-2014, 10:36 AM   #9
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Switching to a fixed back seat would get you better results but doing that in a car without roll over protection is not something I would do. For those of us that build our cars around a rule set of what you can and can not do to your car, for me in STX for example we have a seat weight limit (I won't get into the history of that rule haha) for 25 pounds. IF the stuff in the seats got them closer to that weight it would be an effective thing to do. 10 pounds a seat put them at about 25, or close enough for the lack of cost I would be happy.
What are you wanting to do with the car? That's what you have to ask yourself. So many people just randomly add and remove things from their car. For your goal, is that 5-10 worth it or should you just save weight else where, and if you aren't building to a ruleset, you have plenty of places to remove it more effectively without messing with personal safety.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following User Says Thank You to SubiePig For This Useful Post:
troek (02-19-2014)
Old 02-19-2014, 11:19 AM   #10
troek
troek's Avatar
thanks for the informative post. i just track my car for fun, kind of compete against my friends and what not. i realize for many that is not a reason to remove a safety item like an airbag. im just looking around at different ways to save weight. i was hoping someone might have the weights of the airbags, but unfortunately i think im the first idiot to think of this lol. if i ever get around to taking them apart and weighing them out of curiosity ill post the info in this thread.
SubiePig (02-19-2014)
Old 02-19-2014, 11:50 AM   #11
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
A billion times over.
Here's something I posted the other day as it relates to getting a rollbar in a Miata. The stock seats in those cars are pretty low and you can very easily hit your head on the bar in a collision.
Summary: If you replace one thing, you need to replace everything. And even then you're probably not helping for a street car. If it's a track-only car with HANS etc. then go for it. All of it.
If you do get one, get one with padding. Even still, that might prevent you from dying but you'll at least get a nasty concussion if you hit the bar. It could still be worse.
Then you could get racing seats which are higher in the back and your head won't hit the rollbar. But you shouldn't use a racing seat with the stock seat belts, so harnesses (and a harness bar!) it is. But with all that it's hard to get in and out. Time to replace the steering wheel with an aftermarket one with a quick release. But that takes away your airbag (if you trust a 15-20 year old airbag anyway).
None of that is really safe for the street. It may or may not be DOT approved, and since harnesses don't restrain your neck, you can possibly have bad whiplash from a relatively minor collision. And you can't turn your head easily when you're strapped in so visibility might be reduced. And less significantly but still notable - if you're uncomfortable, that can be a distraction. Racing seats aren't exactly plush.
In other words, you can quickly be spending a lot of money on your street car and might be making it more dangerous. Maybe. It's your call. Do you think you're more likely to roll or to be in a collision where your head would hit the bar?
fourvalleys is offline   Reply With Quote
The Following User Says Thank You to fourvalleys For This Useful Post:
Old 02-19-2014, 11:55 AM   #12
SubiePig
Sold one of my miatas to a friend of mine years ago that had a seat and rollbar with padding on it. He took the seat out and ended up getting in a wreck and hitting his head on the bar. Luckily it was padded.. somewhat..
Old 02-19-2014, 12:29 PM   #13
acx23
Drives: 2013 FRS (Silver)
If you're just tracking for fun, there is no real reason to shave weight by gutting the seat because you will not feel the difference, since the seat bracket is where most of the weight is. Plus the stock seats holds you in pretty well during turns.
The stock tires and pads are crappy (the pads don't even last more than 2 sessions at Laguna Seca) so I would definitely look into getting better tires and pads and good DOT4 brake fluid if you haven't already done so. This is what I did right after I got my car because I know I will be tracking it. I already did 3 track days within the first 3000 miles on the car with just tires, pads, lines and fluids.
This is a great kit to start off with and you can probably find it cheaper elsewhere http://www.evasivemotorsports.com/mm...Fc1hfgodz1sArw
Good luck and stay safe.
acx23 is offline   Reply With Quote
Old 02-19-2014, 12:37 PM   #14
canu_50
canu_50's Avatar
Drives: Scion fr-s
One of my customer died this summer at Mont tremblant.. Porsche GT3 RS 2008, with factory seat and race harness, caged car, hans device! No head restraint seat.. He sideswipe in the wall at around 160 km-h in corner 6.
I will jump over the detail, but if he had a headrestraint seat, he would propably still be alive.
Gutting primary cat? jordanrw260 Engine, Exhaust, Transmission 6 07-30-2018 10:24 PM
Gutting out the stock cats diss7 Engine, Exhaust, Transmission 90 04-02-2018 12:57 AM
Scion FRS Stock Full Seats (Driver / Passenger / Rear seats) for sale Sehwan Kim Interior Parts (Incl. Lighting) 1 01-28-2015 07:35 AM
Gutting the BRZ and putting in a Electric Engine? mechaghost BRZ First-Gen (2012+) — General Topics 22 07-31-2014 07:12 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 06:45 PM
